2x OT12
Jake Jarmon
2x OT12
#1 Post by Jake Jarmon »
Something very satisfying about cutting flat packs on a table saw.
The way the chisel goes through warm PL mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm :fruit:
2 - T24 24" BP102 "Twinning"
2 - OT112 Delta Pro 12 Melded Array **In Progress**
Re: 2x OT12
#2 Post by Tom Smit »
Good progress.
Is that 3/4" plywood?
Re: 2x OT12
#3 Post by Chris_Allen »
Tom Smit wrote:Good progress.
Looks like 1/2" stacked together, 2 pieces for each cut.
On the edges of your cuts, it looks like you have a bit of gripping from either your fence or table top - might be time for a quick light sand and a bit of wax.
Jake Jarmon
Re: 2x OT12
#4 Post by Jake Jarmon »
Yes cutting 2 baffles at once. You are right I cleaned the table and fence a few weeks ago but it definitely needs some more TLC.
Re: 2x OT12
#5 Post by Tom Smit »
Oh, good. Just checking. :)
Jake Jarmon
Re: 2x OT12
#6 Post by Jake Jarmon »
Can I rotate the woofer spacer 22.5 degrees so the points are 0,90,180,360 when I install it without adverse effects? It looks cooler that way and is much easier to align.
Re: 2x OT12
#7 Post by Bruce Weldy »
Jake Jarmon wrote:Can I rotate the woofer spacer 22.5 degrees so the points are 0,90,180,360 when I install it without adverse effects? It looks cooler that way and is much easier to align.
Yep....it only serves to give more holding power to the screws.....
