Boxing tape trick
halftank
Boxing tape trick
#1 Post by halftank »
Here is a great tip for you newbie wood builders, a simple method I have use for many years is the CLEAR BOX TAPE. it works the same as the wax paper but affords you the sticky side to attach to your backing/support boards. You can even use it to make line mould for doing fibre glass layups. Happy building
Wayne
kkip
Re: Boxing tape trick
#2 Post by kkip »
Boxing tape...from the title I was envisioning the sort to thing that Rocky Balboa would have wrapped around his hands before entering the ring.
1 x TAT - GTO804
Curtybob
#3 Post by Curtybob »
Nice. I stay away from it because of cabinet building. The glue can leave a residue that can have some odd ugliness when going with stain. But for this, it does seem to make sense.
