2 series & 1 parallel
I have a inuke 6000 amp that produces 97v per channel. it can only do 4 ohm or higher. I have two t48s with 4ohm lab 15 subwoofers which makes each sub 6ohm. when I build more t48s could I hook up three on one channel, 2 series and one parallel to make the amp read 4ohm? if not its fine, i'll just get another amp
Re: 2 series & 1 parallel
And that sir, is the correct answer.truitt wrote: i'll just get another amp
