Behringer EPQ304 Experiences
nola50
#1 Post by nola50 »
I'm considering using one of these to power monitors. $ 229 at PE.
The four channels can be paired to provide additional power, if needed.
See more at: https://wholesale.parts-express.com/beh ... --248-6564
Specifications: • Output power, stereo (all channels driven): 65 watts RMS x 4 (4 ohm / 1 kHz @ 1% THD), 40 watts RMS x 4 (8 ohm / 1 kHz @ 1% THD), 75 watts peak x 4 (4 ohm / 1 kHz), 50 watts peak x 4 (8 ohm / 1 kHz) • Output power, bridged mono (2 pairs channels bridged): 130 watts RMS x 2 (8 ohm / 1 kHz @1 % THD), 150 watts peak x 2 (8 ohm bridge mode) • Dimensions: 1.9" H x 19" W x 10.4" D (49 x 482 x 265 mm) • Weight: 8.8 lbs (4 kg). -
Guitbusy
Re: Behringer EPQ304 Experiences
#2 Post by Guitbusy »
FYI. The link is to something in the wholesaler account, not accessible by those without such account...
1 x Tuba 24 (24"x24"x24")
2 x Wedgehorn 6
2 x SLA Pro Shorty (2x6)
nola50
#3 Post by nola50 »
#4 Post by Bill Fitzmaurice »
No hype there. :roll:
The remarkable 4-channel EPQ304 packs a heart-stopping 300 Watts of output power
Better not touch the output leads. :cop:
It takes huge pulses of energy (current and voltage) to propel a woofer cone out fast enough to match a bass beat. That’s called Transient Response and it’s the holy grail of amp design
That's not what transient response is. :noob:
At 4x50w/8 ohms it's probably sufficient to drive Wedgehorns.
If it was me I'd go with this, not just for the higher power but the on-board DSP:
http://www.carvinaudio.com/collections/ ... -power-amp
