FOH and Monitor mixers- connecting them.
Posted: Wed Oct 14, 2015 4:28 pm
I know it's so old school lol, but I just bought a Soundcraft Monitor 16/8 channel monitor mixer (for $180AU
). It's supposedly totally functional, yet to go right through that, it will be when I'm done one way or the other.
I'm scratching my head a bit about hooking up both when I have one 100ft/30m multicore that doesn't have parallels/splits on the stage box.
I will use them, when needed, with both mixers run from the same power source (to help eliminate ground loops/hum).
I've been reading before posting this thread.
Some say that a splitter with isolation transformers is required. That's big $ to buy a commercial unit.
Others suggest parallel outs, or mic cable splitters on the stage box will, more often than not, be fine (there's some thoughts about phantom power being an issue).
On smaller gigs with one or two sends, I'm ok with using a couple of my Aux sends on the FOH mixer.
LArger jobs, I want to free up the Aux sends for FOH use.
How do the learned fellas here hook up monitor mixers???
