Hi!
What processor do you guys use for monitors?
I run a mono PA and I use 4 or 5 separate monitor sends from my mixer.
Can I use three Driverack PA2´s?
-one for mono mains and monitor channel 1
-two Driveracks for monitor channels 2,3,4,5
Lars
Edit: maybe two Driverack Venu360 would be easier (but a little more expensive..)
Driveracks for many monitors?
Making six or twelve DR200`s, great fun!
Also have two T39´, a T48, four W8´s and two W6´s in the making
No, I´m not in a hurry...
Allen&Heath GL2200 16ch, Allen&Heath SQ5, DBX Venu360, DBX dr PA
Re: Driveracks for many monitors?
I use two driveracks on 4 of my sends and run the other two using just the Graphic EQ on my digital board.GNUlars wrote:Hi!
Lars
You can't really run the monitors and mains on one driverack. The crossover controls both channels, so if you want full range monitors....ain't gonna happen.
- Chris_Allen
I used one driverack which gives me the ability to measure frequency response of all my speakers so I can set EQ. I tend to do this independantly with the monitors but the main PA always gets a full response test at every outing. I capture the EQ for the monitors as a reference point.
The driverack only sits on the main outputs and I use the 31-band EQ in the digital board to control the output to the monitors via the Aux outs. Alternatively, I can use the EQ in my DSP power amps but the parametrics don't give as much control.
Note that Bruce and I are in two completely different scales of operation. My rig is much smaller for lighter duty and portability. Looking at the scale of your building adventure, you should be looking more towards Bruce's design paradigm.
I can't believe how much more control I have over sound in comparison to 10 years ago. Then again, I had absolutely no idea what I was doing 10 years ago! (Maybe some things haven't changed much....)
Oh, so you can´t route the channels independently on the Driverack PA?Bruce Weldy wrote:
-Then the Venu360 is the way to go... Very flexible! I downloaded the app for it and did a configuration with one of the three inputs running mains to three crossed over outputs. The remaining two inputs makes two monitor channels to one output each. (still one remaining output, seems it can be used for a mix of the two monitor channels...)
It seems impossible to run the Driverack PA2 control app without connecting to an actual unit, shame...
Lars
