Two 4-Ohm cabs daisy-chained for 8-Ohm load?
Posted: Wed Jul 29, 2015 7:59 am
by rbarone
Hello - Wondering if there's an answer out there... I have two 2x12 guitar cabs with 8 ohm speakers wired in parallel for a 4 Ohm load. I'd like to add a jack & daisy chain them in series, to raise the total load to 8 Ohms. Is this possible without anything other than a properly wired jack? If so, can someone please diagram or explain this? Many Thanks.
Re: Two 4-Ohm cabs daisy-chained for 8-Ohm load?
Posted: Wed Jul 29, 2015 8:58 am
rbarone wrote:Hello - Wondering if there's an answer out there... I have two 2x12 guitar cabs with 8 ohm speakers wired in parallel for a 4 Ohm load. I'd like to add a jack & daisy chain them in series, to raise the total load to 8 Ohms. Is this possible without anything other than a properly wired jack? If so, can someone please diagram or explain this? Many Thanks.
It would be better to series wire the individual speakers inside each cab to get a 16 ohm load. Then just run the two cabs parallel for an 8 ohm load
Posted: Wed Jul 29, 2015 9:38 am
+1. The alternative is to series wire the two cabs, which can be done but it's a PITA. But I'll also say that no one needs four twelves. Reaching the entire audience is the job of the PA, not the back line.
Posted: Wed Jul 29, 2015 11:47 am
by James Champer
Bill Fitzmaurice wrote:Bruce Weldy wrote:But I'll also say that no one needs four twelves. Reaching the entire audience is the job of the PA, not the back line.
Oh how I wish all guitardists knew this.
Posted: Wed Jul 29, 2015 3:27 pm
by rbarone
Thanks all.
Agreed, 4x12 is generally overkill... but to the original question -
I have two 4 Ohm 2x12 cabs for two SS amps that like running @ 4 Ohms. I also have a tube amp that only likes 8 ohms, so I was looking for a way to simply mod the 4 Ohm cabs to use with the 8 Ohm amp.
Gear is left at different locations & it would be pretty convenient if I could work out the ohm-matching problem.
Posted: Wed Jul 29, 2015 3:52 pm
by NukePooch
Maybe leave the speaker cabs alone (since you use them elsewhere) and make a special series-wired speaker Y-cable? You'd have to make sure you don't try to use it in any other application...
Posted: Wed Jul 29, 2015 3:55 pm
by David Raehn
Make up a custom cable and label it liberally.
Amp out tip -> cab 1 tip.
Cab 1 ring - > cab 2 tip.
Cab 2 ring - > amp out ring.
Posted: Wed Jul 29, 2015 4:00 pm
by rbarone
Thanks! This site is an incredible source of knowledge.
