Two 4-Ohm cabs daisy-chained for 8-Ohm load?
rbarone
#1 Post by rbarone »
Hello - Wondering if there's an answer out there... I have two 2x12 guitar cabs with 8 ohm speakers wired in parallel for a 4 Ohm load. I'd like to add a jack & daisy chain them in series, to raise the total load to 8 Ohms. Is this possible without anything other than a properly wired jack? If so, can someone please diagram or explain this? Many Thanks.
Re: Two 4-Ohm cabs daisy-chained for 8-Ohm load?
#2 Post by Bruce Weldy »
rbarone wrote:Hello - Wondering if there's an answer out there... I have two 2x12 guitar cabs with 8 ohm speakers wired in parallel for a 4 Ohm load. I'd like to add a jack & daisy chain them in series, to raise the total load to 8 Ohms. Is this possible without anything other than a properly wired jack? If so, can someone please diagram or explain this? Many Thanks.
It would be better to series wire the individual speakers inside each cab to get a 16 ohm load. Then just run the two cabs parallel for an 8 ohm load
#3 Post by Bill Fitzmaurice »
Bruce Weldy wrote: It would be better to series wire the individual speakers inside each cab to get a 16 ohm load. Then just run the two cabs parallel for an 8 ohm load
+1. The alternative is to series wire the two cabs, which can be done but it's a PITA. But I'll also say that no one needs four twelves. Reaching the entire audience is the job of the PA, not the back line.
James Champer
#4 Post by James Champer »
Bill Fitzmaurice wrote:
Bruce Weldy wrote:But I'll also say that no one needs four twelves. Reaching the entire audience is the job of the PA, not the back line.
Oh how I wish all guitardists knew this. :wall:
rbarone
#5 Post by rbarone »
Thanks all.
Agreed, 4x12 is generally overkill... but to the original question -
I have two 4 Ohm 2x12 cabs for two SS amps that like running @ 4 Ohms. I also have a tube amp that only likes 8 ohms, so I was looking for a way to simply mod the 4 Ohm cabs to use with the 8 Ohm amp.
Gear is left at different locations & it would be pretty convenient if I could work out the ohm-matching problem.
NukePooch
#6 Post by NukePooch »
Maybe leave the speaker cabs alone (since you use them elsewhere) and make a special series-wired speaker Y-cable? You'd have to make sure you don't try to use it in any other application...
David Raehn
#7 Post by David Raehn »
Make up a custom cable and label it liberally.
Amp out tip -> cab 1 tip.
Cab 1 ring - > cab 2 tip.
Cab 2 ring - > amp out ring.
BFM rig:
6 OT12
4 T48
4 WH8
Other:
56 box Electrotec LabQ rig
Way too many cables
:noob:
rbarone
#8 Post by rbarone »
Thanks! This site is an incredible source of knowledge.
