J-Array brackets for 4 cabinets in each array
vesthardt
#1 Post by vesthardt »
Hello!
I can't figure out from looking at the plans how to setup the brackets for 4 cabinets per side in the J-array. Anyone who can help me understand? :)
Thanks,
vesthardt
Re: J-Array brackets for 4 cabinets in each array
Look at your Sketchup. Four is the same as three, with one more added to the pile.
vesthardt
#3 Post by vesthardt »
So the extra cab should just be same angle as the top one without spacing between them?
4x Titan48, 18" wide loaded with Kappalite 3015LF
Bought:
2x DR250 w/ deltalite 2510 II
Building:
8x Omnitop 12 J-array w/ Delta Pro 12A and Melded/flat tweeter arrays
4x Titan48 18" wide w/ Kappalite 3015LF
#4 Post by Bill Fitzmaurice »
The angles that the cabs are set at depends on your installation. That's why there are multiple holes in the brackets, so they can be set as required.
