So i recently bought a 300W plate amp for my TableTuba and i am going to build it into a wooden case. My question is: Can i build-in an analoge voltmeter directly parallel to the speaker output?
Voltmeter:
http://www.ebay.nl/itm/UPDATED-Analog-V ... 27f67293c5
Amplifier:
https://www.conrad.nl/nl/inbouw-verster ... 01044.html
Woofer:
JBL GTO804
build a voltmeter into plate amp
Re: build a voltmeter into plate amp
Why not, however you will need an AC volt meter. The meter you listed is DC.
Thanks for your reply. Thanks for reminding me about the AC, totally forgot about that
- Jake Jarmon
2 - T24 24" BP102 "Twinning"
2 - OT112 Delta Pro 12 Melded Array **In Progress**
And why should i use that instead of just buying an AC voltmeter and connect it parallel to the speaker output?Jake Jarmon wrote:https://www.parts-express.com/yuan-jing ... --320-6550
