Driver used is a Eminence Kappalite 3015LF. I'll be powering my system with a single Behringer NU4-6000 amp which is about 300W RMS on 4 channels. Right now running a stereo main feed, mono sub, and single monitor feed (turned WAAAY down for the WH8's).
First impressions are very good. Been messing around with the crossovers a bunch and trying to get the levels straight between the highs and lows. It definitely can't keep up with the SLA's (as expected), but what bass is there sounds great. Way cleaner and tighter than the 18" powered Seismic sub I just returned. Weight is around 48lbs. Really easy to lug around. I'm thinking of building another to run in parallel.
