Should I?
Should I?
Apparently I have access to a signal generator that sine, square, triange, ramp, noise as well as programming some arbitrary ones. It goes up to 15Mhz, (with and'M'). What would I use such a device for since I have the Binks CD and a couple of other sig gens. on my laptop?
Re: Should I?
Beam sound into space to contact extraterrestrial life?
Re: Should I?
I have a signal generator, hardly ever use it. I used to when measuring impedance, T/S specs and frequency response, but WT3 and HolmImpulse do those chores better and in a fraction of the time.
David Raehn
Re: Should I?
Look at the bottom of the following page:
http://www.arx.com.au/International/Six ... pnotes.htm
Use this approach to fatten up the kick.....
BFM rig:
6 OT12
4 T48
4 WH8
Other:
56 box Electrotec LabQ rig
Way too many cables
6 OT12
4 T48
4 WH8
Other:
Way too many cables
Re: Should I?
+1draehn wrote:Look at the bottom of the following page:
I've even got the ARX six gate to use on the technique
Tom,
Sure, if you have the need for 15Mhz, go for it...
