I run the sound for some small club nights with the T 48's.
The DJ has upgraded to the mixer below but we can't figure out how to output mono from it into the DCX. Any DJ's on here have any suggestions? I can set the dcx up for stereo but that's not ideal.
Ta.
http://www.allen-heath.com/ahproducts/xonedb4/
Mixer issues
Re: Mixer issues
Run your L and R outputs of the mixer to the DCX inputs A and B. On the DCX in the "SUM" menu, on page 1/5, select "SUM" to be "in A + in B". Then on every output you use (1 thru 6) in the General menu on page 1/8 select your "input source" to say "SUM". You now have the DCX converting your stereo inputs to be mono outputs.
Re: Mixer issues
God this forum is handy!
Thanks mate!
Thanks mate!
Re: Mixer issues
That db4 mixer is a beast. Not cheap though (although next to my BFM addiction, it's small change!)
