Howdy again folks!
As it states. I know Bill has specified particular wire gauge for the drivers. Also stated to use smallest available wire gauge for coils for filters. Should I be trying to match the driver wire gauge to the coil gauge or as close as possible? Or does it even matter being the coils are what the are? Again thanks in advance.
Wire gauge to match coils?
Semper Fi
TX
TX
Re: Wire gauge to match coils?
You have to follow the plans. Some coils are just shunts to ground so smallest diameter wire you can find is fine to save some weight and money. Other coils carry the full current so Bill lists the minimum DCR (resistance) that is acceptable, these ones use a much larger wire and are much heavier and costly.
Smaller gauge wire increases the resistance and lowers the Q of the coil. It's better to use heavier gauge wire when possible to keep the DC resistance as low as possible.
T48s
WH8s
SX212
T48s
WH8s
SX212
- Rune Bivrin
If you're referring to the wiring between Speakon and cross-over or cross-over and drivers there's little to worry about. The lengths are so short you can get use #18 AWG for pretty much anything. Two feet of #18 is 0.0255 ohms. Pretty insignificant. Even #20 is generally OK.
There's no "matching" to consider.
For the coils in the cross-overs, on the other hand, you need to be mindful of the gauge.
In build order:
O12 with no tweeter.
3 x WedgeHorns.
2 x Jack 10 without tweeters.
2 x DR250.
2 x 16" T39
1 x Tuba 24
2 x SLA Pro (sort of...)
3 x WedgeHorns.
2 x DR250.
2 x 16" T39
1 x Tuba 24
I think I misunderstood the question. I was speaking of the wire gauge of the coil windings.
T48s
WH8s
SX212
T48s
WH8s
SX212
So if my coil wrapped with 22awg and the wire from drivers to crossover are say 16awg then there shouldn't be an issue? Noob here just trying to get all my ducks in a row before I start with the dust.
Semper Fi
TX
TX
None at all.TXATC wrote:So if my coil wrapped with 22awg and the wire from drivers to crossover are say 16awg then there shouldn't be an issue?
Thanks everybody! Item 22 off the list. 1276342 more.
Sometimes I wonder if I over think things....
Semper Fi
TX
TX
