So this is it, anyone know what it's officially called so I can get one ordered?
Thanks
+1.ketoet wrote: Wouldn't it be easier to replace te socket with the standard uk version?
Anyone qualified to swap it would have no issues getting it right. The amp says right on it what the mains voltage is, and identifying the +/-/ground is a simple matter.bjm362 wrote: One more time though, just switching it over to modern plugs might work perfectly, might work marginally, or might fry it totally.
With all due respect, there is no information in that post or pic that the amp says anything about voltage. The Pic shows that it has the lettering A.C. MA Which is the start of A.C. MAIN. You may actually be correct that that info is on the amp, but thus far I haven't seen that information. I have seen those plugs before though as a child... and as a child I was taught that if I was going to err I should err on the safe side. You may be right that a direct swap will work. Considering the variety of voltages that that could be I still believe proper research should be done first. I am not saying you are wrong, just that I don't see enough info there to draw that conclusion! I hope this doesn't mean you are now going to hate me!Bill Fitzmaurice wrote:Anyone qualified to swap it would have no issues getting it right. The amp says right on it what the mains voltage is, and identifying the +/-/ground is a simple matter.bjm362 wrote: One more time though, just switching it over to modern plugs might work perfectly, might work marginally, or might fry it totally.
Note that example one will plug into a US 117VAC receptacle, example 3 is listed with a 250VAC rating.Switch either of those and an amp fries. Those were used both ways and more by manufacturers across the globe in my youth, which also happens to be the era of production of the amp in question. None of you have researched what the amps input voltage is, nor has enough information been provided to do so. Guessing may work, or may spell unnecessary disaster. This is my final comment in this thread. We already knew those plugs were used in the UK...and other places. That was the whole point of my comment about doing the research. That simple plug found its way on multiple continents used with equipment at several voltage standards. This isn't like USB. You can take the right plug, and use the wrong voltage and FRY equipment.draehn wrote:Here ya go:
http://www.dadaelectronics.eu/shop/quad ... cable-50cm
http://www.ebay.co.uk/itm/BRAND-NEW-BUL ... 0669467232
http://www.mouser.com/ProductDetail/Bul ... 7HTqfiPw==
Interwebs is handy sometimes.
Originally made by Bulgin. It is a UK standard.
Cheers.
Voltage in the US routinely varies from about 105v to 120v, so 220v shouldn't bother anything originally designed for 240v.Grant Bunter wrote: More of a concern perhaps, is; will 220V still run the amp without it getting to hot?
I am glad you found the one thing I was over looking, you already know the location!!!! That changes things pretty dramatically ! Sorry if I created any headaches.Grant Bunter wrote:bjm362,
It's not guessing when we know the OP's location.
He is in the UK, and they had a 240V/50 cycles supply.
However, to align themselves with the rest of the European Union, the UK are winding down their standard from that mark, and currently sit at 230V. The target will be 220V.
Or, along with the plug, does the power supply need looking at too?
