T Nuts
Tom O'Shea
T Nuts
#1 Post by Tom O'Shea »
I saw the other day where even Leland was spinning tee nuts on his OT 15 build.
I've switched tee nut suppliers from PE to McFeely's. www.mcfeeleys.com
McFeely's. Heh-heh. Great name. Heh-heh.
They sell some pretty tough tee nuts, with four big-ass spikes instead of six dinky ones. They're made of stouter steel than the PE tee nuts, too.
You CAN still spin them--at least I can--but it's harder. On my current build I'm using 32 tee nuts in two cabs, and I've only spun one. With the PEs, I might have had problems with four, or even six.
But they cost more, and their only thread guage in #10 screw size is 24 TPI. Still, they've reduced cussing time by at least a little bit per cab.
McFeely's also sells pretty good screws. Heh-heh. He said Screws.
Tom O'Shea
Tim A
#2 Post by Tim A »
Use a fender washer on a screw and draw the T-nut in, don't tap it. That assures perfect thread allignement when you are ready to put the screw in.
Also, once I get it started I put a dab of poly glue, like Gorilla or the Elmers verion on the shank. It won't come out or spin.
Art Coates
#3 Post by Art Coates »
Tim Ard wrote:Use a fender washer on a screw and draw the T-nut in, don't tap it. That assures perfect thread allignement when you are ready to put the screw in.
+1
Harley
#4 Post by Harley »
+1
I even have a cut off allen key that I use in my battery drill ( slow speed ) which saves a huge amount of time - real important that glue dab!
I assume by a fender washer you mean what we call a penny washer- obout 1/4" ID and 1-1/2" OD
Harley
mk_drums
#5 Post by mk_drums »
penny washers hey
i wonder if they call them that across the pond here
i needed some fender washers when i was building a drum kit last year and no one knew what they were. the specialist fastener shop even said no we dont have anything like that
i sadly had to end up buying some from the US
Christian
#6 Post by Christian »
I did the exact same thing! In my humble opinion, that is an excellent tip! I hate manually driving anything (other than the GF... :P )
You can even buy allen bit extensions so you can drive the hex head from a distance. This is mandatory for the tighter cabinets; like a T-30. My old drills aren't streamlined enough to reach the screws :oops: But with a home-made driver, everything is peachy!
But yeah, like Tim said, you have to PULL the T-nut in, not hammer it.
We're talking speakers, right...?
Harley
#7 Post by Harley »
Christian wrote:
You can even buy allen bit extensions so you can drive the hex head from a distance. ..?
I thought of those bits but they wear out real quick and are damned expensive here. An Allen key costs very little - I buy the long ones and cut about 3 bits out of it with the small grinder ( hacksaw is useless )
One little bit does about 75 teen nuts.
Harley
Harley
#8 Post by Harley »
mk_drums wrote:i needed some fender washers when i was building a drum kit last year and no one knew what they were....
Bet you if you'd gone to one of your traditional hardware stores and asked for a penny washer - they'd have known what you were talking about.
I did some installations of a/c filtering equipment in Oz many moons ago and we obtained penny washers from the local h/ware ( in Sydney )
Harley
#9 Post by LelandCrooks »
This is the first time I've had a nut spin since I switched to hurricane nuts from regular tee nuts. I always put a dab of PL on the them, and pull them in just like you all described. I've also switched to hex cap screws, and you get lots more torque than with a phillips screw. I don't have the "feel" for how hard to pull them yet. From now on they get a shot of 5 min epoxy. I also keep a tap handy and hit every one after insertion. with a little practice you can run it in the drill. SLOWLY.
Great minds think alike. Hacksaws just polish the shank. Die grinders make pretty short work of it.
I find the biggest problem is driving the bolts with a drill, if things are AFU it will strip the nut before you're aware of a problem. I drive the bolts by hand only, and if they feel the least bit hinkey I chase the both the bolt and nut threads.
Tim A
#11 Post by Tim A »
Bill Fitzmaurice wrote:I find the biggest problem is driving the bolts with a drill, if things are AFU it will strip the nut before you're aware of a problem. I drive the bolts by hand only, and if they feel the least bit hinkey I chase the both the bolt and nut threads.
I agree. A happy medium is a screw gun with the torque setting on 1 or 2. If it cross threads it'll slip the clutch almost immediately but runs the bolt in fast on a clean thread. Finish up with a hand tool or crank the clutch down.
Harley
#12 Post by Harley »
Bill Fitzmaurice wrote:I find the biggest problem is driving the bolts with a drill, if things are AFU it will strip the nut before you're aware of a problem. .
True, but I hand spin the nut up a couple of threads beforehand and you know if you have cross threaded by then. I use a M5 x45mm HT Allen headed screw.
Harley
