Direct Box Recommendation
Hackomatic
#1 Post by Hackomatic »
Looking for some ideas to replace the passive direct boxes I'm using at one of my venues. I've now experienced 3 failures with the Elite Core DIR-2 boxes that were recommended to me. Yeah . . $59 for a duel was a bargain, but the transformer inside is an apparent weak point as 3 have opened.
We can send a man to the moon, can we not make something as simple as a passive direct box bullet proof?
:chainsaw:
Dave H
byacey
Re: Direct Box Recommendation
#2 Post by byacey »
If I might suggest: If the enclosures and connectors are reasonably good quality, purchase some good quality transformers and swap them out. This will give you the best quality bang for the buck.
T48s
WH8s
SX212
BrentEvans
#3 Post by BrentEvans »
+1 to Byacey's suggestion. The OSP?EC direct boxes sound good, but I've had one fail too.
If you're looking for a good pro level DI, look at Radial.
gdougherty
#4 Post by gdougherty »
ProDI if you're on a budget. JDI heartily recommended if you can swing it. The Countryman Type 85 is also a die-hard active that's worth having on hand. All mine are actives these days. I carry J48's for mono sources and Audiopile LDB-202 dual channel actives for stereo box needs. I have had one of the Audiopile lose a channel. but I have 4 that have also been problem free. For an $80 dual channel direct box built almost as well as the Countryman I can't complain. If one goes bad, I'll pick up another and keep a stock of 4 working.
byacey
#5 Post by byacey »
The electronics in the Countryman aren't repairable as it's potted in epoxy, but they are very reliable and have a lifetime guarantee from Countryman. If you ship the defective DI back to them, they'll replace it.
For replacement transformers, check out Lundahl, Oxford, Cinemag, Sowter, Jensen, etc.
This website has a plethora of info regarding audio electronics:
http://groupdiy.com/
If you have any electronics construction experience,you might check out my DI box thread:
http://groupdiy.com/index.php?topic=1162.0
T48s
WH8s
SX212
Hackomatic
#6 Post by Hackomatic »
byacey wrote:If you have any electronics construction experience,you might check out my DI box thread:
As a broadcast engineer by day, I know my way pretty well around schematics and circuit boards. :wink:
Unfortunately, the DIY link on the groupdiy board is dead so I can't jump headfirst into sifting your homebrew DI.
Dave H
byacey
#7 Post by byacey »
The link is long dead; it was hosted by a technician in Australia, but I posted the schematic later on in the thread. If you want the whole article from the original website, let me know and I'll send it by email.
T48s
WH8s
SX212
Hackomatic
#8 Post by Hackomatic »
Okay . . scrolled far enough down to find it. Although the layout and construction would not be a problem, I'm looking for quick and simple and passive. Think I'll just get a couple of Radial ProD2s.
Thanks for the input!
Dave H
byacey
#9 Post by byacey »
You're not going to consider replacing the transformers? You'll wind up with a better DI than you can buy for the same money.
T48s
WH8s
SX212
#10 Post by Tom Smit »
BillY, how much to build that DI box?
byacey
#11 Post by byacey »
Parts including the enclosure is probably around $50.00 CDN.
T48s
WH8s
SX212
Hackomatic
#12 Post by Hackomatic »
byacey wrote:You're not going to consider replacing the transformers? You'll wind up with a better DI than you can buy for the same money.
I considered it. But quite frankly, the overall construction quality of the Elite Cores leaves a little something to be desired. Two of the three that had transformer failures also had padding slide switches break. Time is of the essence right now . . Plus, it ain't my money I'm spending! :lol: (though I am always conscientious when spending OPM)
I will probaly give the Countryman Clone a go when I dig out from the plethora of projects I've got going on at present.
Dave H
