Page 1 of 2
SLA Pro build thread
Posted: Fri Jun 27, 2014 1:58 pm
by Chris_Allen
So, the time has come again for me to build another design. As part of what feels like "collect the series" I'm building a single SLA Pro.
The first stage of this project was getting access to my table saw. The garage has been a tip for far too long and I've spent more time organising and binning that will probably take to build it!
I've purchased my Alpha 6's already and they have been through a breaking in process. Although I shouldn't need them for a top, it can't hurt.
The main application for this SLA Pro is a monitor for the electric kit and it is being paired with a T18. These will double up as a very small, portable music rig.
I'm building the four driver version rather than the mini and it will be interesting to see how it stacks up against a DR200.
Re: SLA Pro build thread
Posted: Tue Jul 01, 2014 4:54 pm
by Chris_Allen
Four pieces cut, front back and sides.
Also, the crossover components arrived but the resistors are different from the last time, so I'm not sure if I ordered the wrong ones. I couldn't get 30Ohm resistors, only 33 and 27 were available, so I opted for 27. I don't know what difference it will make.
Here is a picture of the Jack crossover and you can see the different resistor type. Do I need to get some different resistors ordered or will the ones I have do?
Posted: Tue Jul 01, 2014 5:20 pm
by Grant Bunter
Wire wound, with ceramic white coating, as per your top pic, have been fine in my DR's.
Oh, and they came from Leland...
Posted: Tue Jul 01, 2014 8:51 pm
The resistors are within the requisite 10% value tolerance.
Posted: Tue Jul 01, 2014 11:14 pm
by sine143
nice saw! love the dado's, did something similar with my cabs via cnc.
Posted: Wed Jul 02, 2014 1:22 am
by Chris_Allen
There is often talk about the orientation of the inductor. Is it fine as it is or do I need to rotate it? I've never bothered before.
Posted: Wed Jul 02, 2014 4:53 am
by Hackomatic
No worries there . . you've got plenty of offset.
Posted: Thu Jul 03, 2014 11:08 am
by ripNdeb
What about a WH10?
Posted: Thu Jul 03, 2014 12:12 pm
by Chris_Allen
ripNdeb wrote:
What about a WH10?
It isn't as flexible and it's massive!
With the T18/SLA Pro combo you can go lower and run the E-Kit in a PA without subs.
Posted: Thu Jul 03, 2014 12:35 pm
by Chris_Allen
sine143 wrote:nice saw! love the dado's, did something similar with my cabs via cnc.
Those look great - what did they look like finished?
I'm really interested to know what the SLA Pro sounds like next to the DR200.
Posted: Thu Jul 03, 2014 1:18 pm
by sine143
Posted: Thu Jul 03, 2014 4:04 pm
by Grant Bunter
I've always been somewhat curious about this concept.
In 35 years of playing live acoustic drums, I can't recall even a big gig I've played where a sub has been used in drumfill. I'm not a fan of kidney bruising drumfill anyway, unlike a lot of (slightly) older guys that are deaf from having that sort of drumfill in the late 60's and 70's, that I have talked to over the years.
More often than not, drumfill is 1 or maybe 2 x 15" fullrange cabs. More than enough to hear thump and click. Plenty for me. Add some snare and vox and I'm good. No toms, cymbals etc.
Depending on stage size maybe add dribbles of bass, guitar and or keys.
Even when running vox only type PA, with a dribble of kick, that's enough thump (via FOH), for me to be able to lock in.
A couple of times here on the forum, I've seen comments about needing drumfill that covers the audible/tactile spectrum of the kit when playing electronic drums.
I simply don't understand why.
If I can't hear 30Hz in my fill (if it's even there from my kick), it doesn't make me play differently.
More to the point, great build Chris
Also rather jealous you just happen to have a 3015lf lying around for your sizing comparison lol...
Posted: Thu Jul 03, 2014 5:00 pm
by Chris_Allen
It's not really a drum fill - it's more a drum back line. I also don't see the need for 30Hz, the choice of the T18 wasn't about bandpass, more about size. With the sub and top being separate (as opposed to the W10/Jack etc) I get far better control of on stage room modes and hopefully the band will be able to here things fine.
The focus is on clarity and volume control. I'm going to test mixing the bass guitar and e-kit into a single back line to conserve further space. I think the T18/SLAP (like the pun?!) will make nice bass cab.
Posted: Thu Jul 03, 2014 5:03 pm
by Chris_Allen
I've wired the crossover, ready to glue:
Unfortunately, no SLA wood cutting today and the Tour De France is in town on Sunday, so hopefully I can finish all the cab cuts Saturday.
Posted: Sat Jul 12, 2014 8:43 am
by Chris_Allen
Got some more time this morning to do some more cutting.
The internal braces are cut:
I've marked the driver holes and the piezo holes as well as the ports/handles. I made a trip to town with the Mrs since the protracter I had was quite simply rubbish. I'm going to redraw all the driver holes before cutting with a jigsaw:
This is all there is to an SLA Pro:
I alway like to do a quick dry fit to make sure everything is in order:
