I've searched and can't find it.
I just got a DRPA for $80 and might get a Ce1000 soon if they'll sell for $100.
Is there a guide for setting up a DRPA?
Re: Is there a guide for setting up a DRPA?
Google driverack PA manual. Then download the PDF.jimbo7 wrote:I've searched and can't find it.
If you get the CE1000, try about 6dB reduction on the limiter for your BP loaded T24.
That will get you very close to 35V.
You have the internal passive crossover in your T24 right?
If so, bypass or remove it.
I have the pdf manual and read through it already. I was thinking/hoping there was a guide like there is for the 2496.Bruce Weldy wrote:Google driverack PA manual. Then download the PDF.
There's a setting for the ce1000 programmed in it already, not sure of its settings, though. I might have to make a custom setup anyways.Grant Bunter wrote:If you get the CE1000, try about 6dB reduction on the limiter for your BP loaded T24.
I do have passive crossovers. Will I need to bypass them in the SLA's?
jimbo7 wrote:I have the pdf manual and read through it already. I was thinking/hoping there was a guide like there is for the 2496.Bruce Weldy wrote:Google driverack PA manual. Then download the PDF.
What do you need to know? Shoot some questions, we'll give some answers.
dbx does kinda' expect you to know what you want. I found the manuals lacking in "how to use it" vs. "what it does".
No questions at the moment. Just hoping there was already a map to guide my way through this adventure.
The Driverack replaces a bunch of traditional equipment and combines their individual functions into one, small single space rack unit thanks to digital signal processing. If you undertsand what these individual units do, pretty much everything in the Driverack is straightforward.
There are a few things not mentioned in the manual, like the FBX adjusting EQ filters on both left and right channels simultaneously. I found this can be a problem when running FOH on one channel and a monitor mix on the other.
T48s
WH8s
SX212
T48s
WH8s
SX212
As far as I am aware, no one has written one similar to what I did for the DCX2496.
I do have passive crossovers. Will I need to bypass them in the SLA's?Grant Bunter wrote:If you get the CE1000, try about 6dB reduction on the limiter for your BP loaded T24.
IIRC you need to do a custom setup, not use any or the pre programmes
If I'm reading this correctly, the passive crossovers in the SLA's seperate low/mids and high frequency. You want to leave that in place.
