I took a DR250 outside and RTA'ed my system again.I actually saved 2 different settings.The first measurement i took,anything greater than -6DB i raised to -6DB,anything greater than +6DB i brought down to +6DB,Then i went into the utility menu and set the gain offset to -6DB,from what i understand that way the signal will never clip in the area's that have 6 DB boosts (?).
I also saved a RTA measurement just as it measured with some +/-7DB and +/- 9DB dips and peaks.I plan to compare the 2 saved measurements and see which one i like the best.
Is there any benefit to using the -6DB gain offset i'm using in the first measurement ?
DEQ 2496 RTA Measurements
djtrumptight
2 Autotuba's MCM 55 2421
8 T48's 24"wide 3015 LF
2 SLA HT systems
1 Table Tuba Dayton DCS 255-4
2 T 39's 20" wide 3012 LF
1 T-18 13" wide MCM 55 2421
2 SLA Pro's
2 SLA HT systems
2 SLA Pro's
Re: DEQ 2496 RTA Measurements
So which setting sounded better?
Where you are testing makes a HUGE difference, too. Ignore anything below 100Hz, and be at least 50 feet away from anything. If you are having +/- 12dB swings, there is something going on.
Umm please someone correct me if I'm wrong.
When you alter peaks and dips by + or - 6dB you are basically heading to a flat response.
If you then alter gain to -6dB all you are doing is reducing output to the DCX by +6dB
I did much the same (ie "mirror image" the SPL chart).
I didn't alter the gain.
I actually find it quite difficult to set up mixer structure to just below clipping and then get clipping in the DEQ. The odd clip every so often isn't a problem.
What's more important is not having clipping occurring a lot on the DCX...
djtrumptight
the-6/+6 sounds better.I agree DJPhatman,and i know what it is.I have a large backyard but when i took that measurement i had the cabs back about 25-30 ft.from the back of my house.I have an even bigger field across the street from me.If i can finish my roof early enough tomorrow im gonna take a cab across the street in the field and measure.
2 SLA HT systems
2 SLA Pro's
2 SLA HT systems
2 SLA Pro's
I wouldn't invest a lot of time measuring them in a field, unless that's where you're using them. The purpose of EQ is to get the best sound possible in the room where you're using them, and every room is different.djtrumptight wrote:If i can finish my roof early enough tomorrow im gonna take a cab across the street in the field and measure.
djtrumptight
I now have a DEQ for both of my systems so i will be using the measurement mic from now on.Bill Fitzmaurice wrote:I wouldn't invest a lot of time measuring them in a field, unless that's where you're using them. The purpose of EQ is to get the best sound possible in the room where you're using them, and every room is different.djtrumptight wrote:If i can finish my roof early enough tomorrow im gonna take a cab across the street in the field and measure.
2 SLA HT systems
2 SLA Pro's
2 SLA HT systems
2 SLA Pro's
