Hi draehn.
You haven't added 2 ohms of acoustic impedance for cabs.
So, with the RMX1450 your load per channel with 2 cabs a channel is 5 ohms.
This is better, when redoing you calculations, you end up with slightly higher voltage output per channel and lower amperage output per channel.
You could use the RMX1450 for a pair of cabs and the MX1500 for a pair of cabs.
Yep, use the DCX with 2 different sub outs to send signal to each amp, as you can have a higher voltage output for the MX1500, leading to overall max output increase compared to your current setup, but still not up to max voltage limit for the 3015lf as per the plans...
