Cutting off 10khz< ??
DJ Higgumz
#1 Post by DJ Higgumz »
Ok so my DR250s sound a bit harsh, and it seems that dropping down all frequencies above 10khz -16db seems to make it sound better, but I'm curious, will it sound like I'm playing lesser quality sound?
Building
4 30" T60s
2 19" T60s
1 30" T39
3 Autotubas with GTO804
Bought
2 Dr250s
J_Dunavin
Re: Cutting off 10khz< ??
#2 Post by J_Dunavin »
EQ to taste. I have a high cut option on my EQ that rolls off everything over 15K. Seems to sound a lot nicer.
As a side note I also bi amp and have the high section on my DRs turned down quite a bit.
#3 Post by Bill Fitzmaurice »
DJ Higgumz wrote:Ok so my DR250s sound a bit harsh, and it seems that dropping down all frequencies above 10khz -16db seems to make it sound better, but I'm curious, will it sound like I'm playing lesser quality sound?
What does your RTA reveal?
Harshness from piezo arrays can almost always be traced to clipping in the electronics.
sine143
#4 Post by sine143 »
My rta mic is not accurate enough above 5khz to trust but i tend to like a wide q cut at around 10khz (3 db) with a 6db lopass at 18khz
DJ Higgumz
#5 Post by DJ Higgumz »
It was clipping in the electronics :slap:
Building
4 30" T60s
2 19" T60s
1 30" T39
Bought
2 Dr250s
#6 Post by Bill Fitzmaurice »
DJ Higgumz wrote:It was clipping in the electronics :slap:
Word is spreading fast about the best club sound system in New England, if not the country:
http://billfitzmaurice.info/forum/viewt ... 30&t=19854
It is pristine clean to 20kHz at insane levels, and the DR280s are all piezo loaded.
