T48 upper Xover point
byacey
#1 Post by byacey »
How high up can a T48 be run before the response starts ringing? Is 130Hz out of the question?
I would test them myself, but I do all my testing outside and it's presently -30C here.
T48s
WH8s
SX212
Re: T48 upper Xover point
#2 Post by Bruce Weldy »
byacey wrote:How high up can a T48 be run before the response starts ringing? Is 130Hz out of the question?
The problem is that once you get much over 100hz, the sound starts to be easy to locate.....and if you have the subs corner loaded, that wouldn't be a good thing.
#3 Post by DJPhatman »
I'm not sure what you mean by "ringing", but the cabinet becomes very locate-able at around 150Hz and higher, making the sound rather unpleasant. Whether passive or active, my ears don't like subs crossed higher than around 125-130Hz.
#4 Post by Bill Fitzmaurice »
DJPhatman wrote:I'm not sure what you mean by "ringing".
That's a resonance caused when parallel walls are 1/2 wavelength apart. 24 inches is 1/2 wavelength at 280Hz. This isn't a concern with a sub, as they shouldn't be run that high, or for that matter within an octave of that, so that the 2nd harmonic doesn't resonate. It is with mains; that's why the DR series has no parallel surfaces, and those in the OTops and Jacks are of the least possible area.
byacey
#5 Post by byacey »
Thanks,
I appreciate the info.
T48s
WH8s
SX212
