Using compatible can spray primer?
djlivex
#1 Post by djlivex »
Can someone suggest a gray spray can primer to be compatible with Duratex and PL glue which I tried to get as much off the Tuba but still has some on BB? I only have 1/3 can of Duratex and my other Tuba 24 needs another light coat of Duratex with color purple mixed in. Should be flat so as to more adhesion, correct? Thanks! :?
Re: Using compatible can spray primer?
#2 Post by LelandCrooks »
I use rust oleum quick dry. It the cheaper version of their sprays. Says 2x on the label, which iirc is gray. Just about any spray primer will work.
