Hello all,
I am in the planning stages to build a set of TLAH that will be floor standing.  The closed end on the floor and open on top.
I will be lengthening the enclosure to about 10-12 inches to accommodate 8-9 5 1/4" mids .  My question is with regards to the closed and open ends.  When lengthening the enclosure can I keep the open and closed ends the same as original? Or do I need to make them bigger, or keep the open end the same and make the bottom larger?
thanks in advance,
Oscar
