Xmax and Xlim
Michael Ewald Hansen
Re: Xmax and Xlim
#1 Post by Michael Ewald Hansen »
TimpBizkit wrote:Why is exceeding x-max so bad? (...)
A lab 12 has an X-max of 13mm and an X-lim of 22mm. So doesn't that mean that driving the speaker to 14 or 15mm momentarily is safe? (...)
Driving the speaker to 12mm xmax is safe - beyond 13 you run a great risk of destroying your driver..
Remember that excursion rises rapidly when you want to reproduce lower octaves.. Often, when it comes to midwoofers or similar, the driver will hit its thermal limit before its mechanical - thereby ruling out xmax as the limiting factor..
Last edited by Michael Ewald Hansen on Tue Oct 15, 2013 4:15 pm, edited 1 time in total.
Authorized Builder - Denmark
Re: Xmax and Xlim
TimpBizkit wrote:Why is exceeding x-max so bad... it's often touted like it will blow the speakers.
That's because it will. Going past xmax you put more power in without getting more output, that results in heat build up and eventually magic smoke.
Eminence Alpha 6 - X-max 3.5mm, X-lim 4.0mm
That's because the Alpha 6 has a underhung coil.
Re: Xmax and Xlim
#3 Post by Bill Fitzmaurice »
If you want to push your drivers past xmax be my guest. Sensible builders will follow the plans and limit their subs.
Re: Xmax and Xlim
#4 Post by Grant Bunter »
Because you're taking the driver beyond it's design capability. Otherwise it wouldn't be called Xmax, it might be something like Xnom, as in nominal. Max to me means short for maximum.
Since you mentioned the Lab12, IIRC, in Bill's designs at least, Xmax and thermal limit occur at the same voltage limit for that driver.
It's already been mentioned that lower frequencies push the driver hardest in terms of travel.
And when you look at impedance graphs for a driver, if they have been supplied, you'll notice that's where the highest impedance is as well...
