Page 1 of 2
Let's see your SLA's
Posted: Sat Sep 21, 2013 3:14 pm
by jimbo7
Just ordered the plans. Looking for ideas as far as finishing goes. Most likely they'll be a flat/semi black so they blend in with the living room, but want them durable enough to use for light pa purposes (parties).
So let's see your SLA's
Re: Let's see your SLA's
Posted: Sat Sep 21, 2013 4:00 pm
by Bas Gooiker
Jimbo,
These are not mine, but some very nice examplesby authorised builders:
But it Herz/Ian Westwood
Funky purple by Patrick Mos
Probably one of the best looking ones where built with dark wood inlays. I can't remember the name of the builder. He was the same guy that did the Otop j-array for his church.
Posted: Sun Sep 22, 2013 2:02 am
by Bas Gooiker
Found them:
SLA for the HT, by lancemhorseley
These should give you some inspiration for your build. Have fun!
Posted: Sun Sep 22, 2013 8:20 am
by jimbo7
Thanks!
That first link is great. The 12th pic down of the baffle speaker centers screwed to scrap so they wont shift when routing is brilliant. Wish I knew that trick before I made my X212.
Posted: Sun Sep 22, 2013 10:35 am
by Benj Ross
Here are some Tlah and Sla tha I built for a client. I need to get the pics up for the Sla surrounds too.
http://billfitzmaurice.info/forum/viewt ... 26&t=17230
Benj
Posted: Sun Sep 22, 2013 12:19 pm
by Ian Westwood
I really like the black body with wooden baffle look!
Posted: Sun Sep 22, 2013 2:02 pm
by Bas Gooiker
I've said it before, but...
Why does everyone ruin their beautiful woodwork with screws through the baffle? There have to be more elegant solutions!
What about these
Ikea fixings?
Posted: Sun Sep 22, 2013 6:27 pm
by bassmonster
Bas Gooiker wrote:I've said it before, but...
What about these
Ikea fixings?
I think those are where the removable grill attaches, not screws.
Posted: Mon Sep 23, 2013 9:32 pm
by anikun07
What about these
Ikea fixings?
Because I followed the instructions?
Posted: Mon Sep 23, 2013 11:32 pm
by Benj Ross
bassmonster wrote:Bas Gooiker wrote:I've said it before, but...
What about these
Ikea fixings?
They are rare earth magnets for the grills. I almost drilled 95% of the way through from the back to glue them in where they could be seen, but I chickened out. Too many hours into them at that point to screw up on the grill mounting. They are pretty low key in real life. Now I am using 1/16" x 1/4" glued to the surface as opposed to 1/8" x 1/4" drilled and mount in the face. Much less time and about the same effect.
Benj
Posted: Tue Sep 24, 2013 6:32 pm
by wallywally
Wood is oak, Finish is Formby's tung oil finish. Baffle is glued and the drivers are loaded from the rear. The tweeters are centered.
Posted: Wed Sep 25, 2013 2:42 am
Sharp. Very sharp!
Oh, and look, no baffle screws.
Posted: Fri Sep 27, 2013 6:42 pm
by biggerrigger
wallywally wrote:Wood is oak, Finish is Formby's tung oil finish. Baffle is glued and the drivers are loaded from the rear. The tweeters are centered.
Wallywally What drivers are used in your build?
Posted: Fri Sep 27, 2013 7:27 pm
by wallywally
4" onkyo closeouts from Madisound. They sold out about 4 years ago. The tweeters are Parts Express onkyo mylar closeouts that are also sold out.
Posted: Mon Sep 30, 2013 12:41 pm
by ketoet
here are my tlah's, haven't got time to build my center sla . but i like to show these whenever i get a chance
