Recommended Saw Blades?
billkatz
#1 Post by billkatz »
Does anybody have a recommendation for a table saw blade that works well cutting Baltic Birch?
1 Omni-15 Tall Boy
2 DR250s
2 Titan 39s
Re: Recommended Saw Blades?
#2 Post by DJPhatman »
Stay away from Harbor Freight/CHEEP Chinese saw blades. There are a bunch of really good blade manufacturers, just get a blade with 40 teeth or more. My personal preference is Irwin and Freud. They are high quality with a budget price.
#3 Post by Bill Fitzmaurice »
#4 Post by LelandCrooks »
Bill Fitzmaurice wrote:Freud Diablo.
http://www.homedepot.com/p/Diablo-10-in ... jW4aJ3D_rc
What he said. Get them resharpened as needed. Usually 10 or $15 bucks. I have 4 that I keep in rotation.
Ian Westwood
#5 Post by Ian Westwood »
I have a collection of blades that need sharpening... where do you get yours done?
Authorized BFM Builder
billkatz
#6 Post by billkatz »
Well, with that sort of agreement, it's off to Home Depot I go!
I know you do a bunch of cutting - how many sheets of plywood can be reduced to speaker parts before a blade needs to be sent out?
1 Omni-15 Tall Boy
2 DR250s
2 Titan 39s
#7 Post by Bruce Weldy »
billkatz wrote: I know you do a bunch of cutting - how many sheets of plywood can be reduced to speaker parts before a blade needs to be sent out?
Probably more than you'll ever build. :mrgreen:
SoundInMotionDJ
#8 Post by SoundInMotionDJ »
If you have a Lowes close by, the Irwin Marathon 80 tooth blades are good too.
http://www.lowes.com/Search=irwin+80+to ... 80+tooth#!
10 T39S + 10 DR200 + 1 T48
#9 Post by LelandCrooks »
http://www.ballewsawandtool.com/index.php
I don't know how many actually. When it starts leaving fuzz on the edges I replace it
rbarone
#10 Post by rbarone »
The Woodworker 2 is probably the best blade going. For what it's worth, I own a woodworking business, I've tried many, & the WW 2 is all I use on my table saw. Nice thin kerf, excellent & lasting performance. Yes, they are comparatively expensive, but the old adage is very true - you get what you pay for. I get them re-sharpened here - http://www.dynamic-saw-blade-sharpening.com They're very reasonable & the blades are like new upon they're return. Get 2 & you'll always have a blade in your machine while the other is off being sharpened.
#11 Post by LelandCrooks »
I've seen that blade recommended several times. One of the few I've never tried. Does it live longer? One of the things I really like about the Freuds is they don't spray sawdust off the top of the blade like many of the others. It throws it straight out, a small amount of dust right in front of the cut.
rbarone
#12 Post by rbarone »
Again, this is only my opinion... I have a few Freuds in the shop.. picked up at the local big box in a pinch, but they just aren't in the same class as the WW2. I've also used other high-end blades like CMT etc. & the WW2 comes out as the best all-around every time. Woodworking is my livelihood, & I am very interested in over-all value... given both cost & performance to consider, I haven't found a better blade for my use.
As far as spray off the top of the cut goes, I don't experience any. My set-up is nothing special or elaborate... a 3hp unisaw with a 5hp dust collection system on the cabinet. No top guard or dust collection.
If you are working on a contractor or job site saw, the benefits of the WW2 are magnified. It's thinner kerf & better edge take less "motor" to make the cut. A sharp WW@ is considered a to make a "glue joint" rip.
Along with a zero clearance plate ( to help reduce tear out at the bottom of the cut ), a WW2 will provide excellent results on sheet goods for both rips & cross cuts.
Take all this chatter for what it's worth... but I hope it helps in some way.
Happy woodworking -
#13 Post by LelandCrooks »
Interesting. I buy directly from Freud, they have many blades you'll never find in the bb's. I occasionally have seen the 60t I use the most.
Thanks! I'll give one a go.
