IPR2 DSP ???
hotrod79
IPR2 DSP ???
#1 Post by hotrod79 »
Can anybody confirm if the dsp in these (specifically the IPR2 3000 DSP) has high and low pass on each channel that are separately adjustable?
I'm am trying to assemble the most compact setup I can because the venues in my area are at times, tiny. I currently run a combo of a PA+ and 1 or 2 PLX3602's. Looking into a IPR2 to runs tops and one side and subs on the other when venue calls for a very small setup of 2- 10" tops and either 1 or 2 of my 4 T24's.
Any information would be helpful, the peavey site doesn't give clear discriptions of the DSP functions.
Thanks
2- Jack 10's
(Sold) 4- Tuba 24's @17" KL3010LF
(Sold) 2- Tuba 30's @26" KL3012LF
Ryan A
Re: IPR2 DSP ???
#2 Post by Ryan A »
The regular IPR dsp model has both, so assuming the IPR 2 dsp would have as well.
sine143
Re: IPR2 DSP ???
#3 Post by sine143 »
I believe the original ipr dsp only lets you put one filter per channel (unsuitable for standalone sub duty)
Michael Murphy
Re: IPR2 DSP ???
#4 Post by Michael Murphy »
I have the IPR 1600 DSP. The cd it came with states it can do both, however when I was fiddling with it I could only get the HP value up, no worries for me cause of the PA + up top, but was wondering the same thing. Perhaps I need to fiddle a lil more or a more experienced user/owner can clarify this.
Ryan A
Re: IPR2 DSP ???
#5 Post by Ryan A »
sine143 wrote:I believe the original ipr dsp only lets you put one filter per channel (unsuitable for standalone sub duty)
READ: the regular IPR dsp model has both. Feels like I'm repeating myself.
It works great for sub duty. The "crossover freq" sets the low pass and the "high pass" sets the HPF.
netwerks
Re: IPR2 DSP ???
#6 Post by netwerks »
hotrod79
Re: IPR2 DSP ???
#7 Post by hotrod79 »
I had seen that manual, but wasn't sure the smaller 2 models would be the same once they are released.
Also just noticed the Crown drive core DSP's @ 8.x pounds. Any advantage on those? Possible voltage limiter and not just db reduction?
2- Jack 10's
Re: IPR2 DSP ???
#8 Post by Bruce Weldy »
hotrod79 wrote:I had seen that manual, but wasn't sure the smaller 2 models would be the same once they are released.
The Crown XLS Drivecore amps don't have the limiters you need for subs.
