I'm cheap but inventive.... I was considering a circle jig for my upcoming build and decided to try an idea:
I have a entry-level router table from a yard sale ($4), a 1/4" straight bit ($3) and some assorted hardware and scrap off of the shop floor($0).
Using a 2' x 6" piece of 3/8 plywood, I drilled a 3/16" hole near one end in which to thread a 1" long 1/4-20 bolt with a 3/4" diameter washer under the head. This slides in the 3/4" slot in the router table and acts as the center. Slide it back and forth to set the inner or outer diameter for the circle and clamp one end to hold it still.
My first attempt yielded a clean cut circle with no runout, and accurate to less than a 32nd.
http://www.guitarpcb.com/apps/photos/ph ... =183541036
Circle Jig...
David Raehn
Circle Jig...
BFM rig:
6 OT12
4 T48
4 WH8
Other:
56 box Electrotec LabQ rig
Way too many cables
6 OT12
4 T48
4 WH8
Other:
Way too many cables
MissileCrisis
Re: Circle Jig...
The jig I have is like the kreg jig for cutting circles but it has holes in it big enough to use a drill but to pivot the router around. By the way it's a piece of scrap wood I found that is roughly 1/4 inch thick. I do all my circles that way and now I have like 10 custom (to the 1/100 of an inch) sized holes for the speakers I've built. Works like a charm and allows you customization beyond standard size which we all know are never ideal for real life speakers (they are always a little off of an even value).
2 x TLAH
1 Titan 39 (lab 12, 15 inch)
1 Tuba 60 (lab 12, 20 inch)
SLA Center
2 x Mini MLTP subwoofers
1 x 212 TH (custom)
2 x Mini-Karlsonators
Owned, but not built
2 x Jack 12 (2512, melded)
2 x TLAH
SLA Center
1 x 212 TH (custom)
Re: Circle Jig...
a piece of 1/8th aluminum ( from a road sign) worth every mile i ran when i stole it
MADE
4- OT12'S BETAII
4 T39'S 20" 3012LF LOADED
ON THE BENCH: 2 OT212
MADE
4- OT12'S BETAII
- Bas Gooiker
Re: Circle Jig...
Clever way of getting materials, and as a tax payer you where already the owner of the sign in some way anyways.Israel wrote:a piece of 1/8th aluminum ( from a road sign) worth every mile i ran when i stole it
Keryn O'Shea
Re: Circle Jig...
Israel wrote:worth every mile i ran when i stole it
Re: Circle Jig...
i was 17 then , i have repaid it thousands of times with my taxes since
MADE
4- OT12'S BETAII
MADE
4- OT12'S BETAII
Re: Circle Jig...
You should've seen my face when I realised the $200 router I bought had no circle jig with it. I toyed with the idea of buying the official one at a further $50 but looking around the garage noticed I had some stuff I could work with quite nicely.
End result:
For all intents and purposes it's perfect. Ghetto as hell but solid. If it breaks I spend 10 minutes making a new one. And yes there's a wee pencil holder for drawing circles too.
End result:
- Harley
Re: Circle Jig...
Very inventive! I like the idea of having the pencil hole.88h88 wrote:End result:
Steven Gustafson
Re: Circle Jig...
Now just build yourself a base to mount your router to. Find the mounting holes on the router, mark the holes onto the sliding part of the jig, then rout out an area for the bit to go through and clear some extra to allow for dust escape.
