Limiter on Crown XLS amps
whines
#1 Post by whines »
So the XLS (1000 in my case) has a binary limiter--on/off. I'm already using a limiter on my DCX, set using a voltmeter. Would you turn the amp's limiter on, under the assumption that more protections are better, or turn it off since it's redundant?
The XLS manual says nothing about the specifics of the built-in limiter or when it kicks in. I assume at the rated output of the amp, but that's just a guess.
Re: Limiter on Crown XLS amps
#2 Post by Bruce Weldy »
whines wrote:So the XLS (1000 in my case) has a binary limiter--on/off. I'm already using a limiter on my DCX, set using a voltmeter. Would you turn the amp's limiter on, under the assumption that more protections are better, or turn it off since it's redundant?
I don't use 'em. They offer no protection for your speakers, they just keep the amp from getting overloaded best I can tell.
