Can I run my plan by you and get some "Feedback" from the "Expert"?
Anyway, I plan on putting a 4 x KSN1165A piezo array in my 2x15 Kappalite 3015 bass cabinets. My question is do you think my "Simple" planed "Crossover" sounds like a good "Crossover" for this build /or would recommend a little different design?
1. piezo mounted 2 over,2under;
2. series-parallel wiring tweeters together;
3. 8ohm-20watt wire wound resister across positive & negative termenals;
4. a 4.7UF-250 volt ployproplyene capacitor in series on the positive termenal.
Any and All Help much apperciate.
Thanks Sincerely Phillip
