Old Iron British Amps.....?
BassheadUK
I was advised in another thread to look at the old english such as C-Audio or Citronic PPX range. I have been watching some one an auction site and the PPX are really really cheap.
Why....?
Is it because mobile DJ's dont want to lug around 22kg amps? Is it because the newer ones consume less mains power so you wont overload a mains socket?
Are they really better than todays lightweight equivalents...?
Why....?
I plan to build a couple of DR250's & Autotuba.
WARNING - LAB12 T39's are EXCELLENT
Re: Old Iron British Amps.....?
dunno bout better. cheaper though
I have a couple of old iron amps and use them in my rig.
They are not user friendly weight wise, they weigh 35kg before I put them in a sleeve.
They didn't cost me much.
It is said that modern lightweight class D amps like clean power to work.
My amps historically are "bullet proof", tour well and work under almost any conditions, including somewhat dubious power in outback Australia.
The main benefit is they are nowadays cheap. I couldn't have afforded to buy them when they were new!
So, if you're prepared to lug some weight, you can save money, if nothing else...
Stay away from the Old H&H amps; the output boards like to catch fire. One thing they designed to last forever though, were the fuses. Even with charred PC boards, the mains fuse was still in excellent shape.
T48s
WH8s
SX212
T48s
WH8s
SX212
BassheadUK
Funny that, I have been watching several and they seem to be the higher priced ones (H&H) - There is one in the cupboard of the charity that I volunteer at thats marked up "DO NOT USE" i was going to drag out and see why, but perhaps I can see why without seeing why.....!
I like the look of the PPX900 - Seems great value and thats something that I'll need after renovating the house and a baby on the way is a cheap amp!
Bas Gooiker
The HH V series is very highly appreciated because of its high sound quality. PPX 900 and c-audio SR series is also great amps. Even at their age they will run effordlesly even in 4 ohm bridge.BassheadUK wrote:Funny that, I have been watching several and they seem to be the higher priced ones (H&H) - There is one in the cupboard of the charity that I volunteer at thats marked up "DO NOT USE" i was going to drag out and see why, but perhaps I can see why without seeing why.....!
The V series came later. I believe they had the Power Mosfet outputs; and I never worked on any of these aside from perhaps cleaning the input controls and blowing the dust out of the cabinets.
It's the S500D that was a large, heavy electronic incendiary device that required the removal of 400 loctited machine screws, all located in near-inaccessible places to service. It was all bipolar transistor outputs.
T48s
WH8s
SX212
T48s
WH8s
SX212
BassheadUK
All the old Citronic PPX amps on the auction sites have dried up now
BassheadUK
What are these Crown XTI's with built in limiters....?
Gotta weigh up the spending £50.00 on a 40kg amp and another £200 on a DCX, or just spending £3/400 on an amp with built in limiter.
what cabs?
you want the XTI 2 series. forget the original xti
BassheadUK
Undecided yet..... Probably starting with a couple of T39's followed by OT12's till I have time to engineer up some DR250'ssine143 wrote: what cabs?
Just seen the prices of the Mk2's.... Ouch.... Cheaper to get an old PPX and DCX for the time being !
I've enjoyed many years of trouble-free service from various PPX series amps. Our old 450 was hammered to within an inch of it's life everynight and never once complained. I put a 900 into a venue as a stop-gap measure to drive a little sub about 8 years ago.. It's still there! Great amps inspite of their weight.
Also consider Cloud CV and VTX series amps. These have a clip limiter in them which can be adjusted by a trim pot which can be handy. Just like the PPX, they weigh a ton but I've never seen one fail, my CV1000 has seen many nights of hammer but continues to do the biz without drama. VTX will sustain 2ohm /ch and 4 ohm bridge and even at the end of the night they're as cool as when they were switched on. Good 'honest' watts out of these..
Hope that helps.
Hope that helps.
Warwick Streamer LX5, Ashton BV300H w/410 & 115.
Leak Stereo 20.
Carver PT2400, MPX1200, 3600VZ etc..
Bikes..
'87 Yamaha FJ1200 1TX
'92 Yamaha FJ1200 3XW
'80 Honda CX500 A
'89 Honda VFR400 NC30
Leak Stereo 20.
Bikes..
'80 Honda CX500 A
BassheadUK
Been watching the auction sites like a hawk and all that ever comes up are the 450's !
I want a 900 !
I want a 900 !
BassheadUK
Took a plunge, Bought a JBL MPX1200 !
Bas Gooiker
Highly regarded sub amp!BassheadUK wrote:Took a plunge, Bought a JBL MPX1200 !
What poor driver is going to get hammered by this beast?
