DR250 and T39
Post links to youtube videos of your cabs.
Forum rules
Lastcat
DR250 and T39
#1 Post by Lastcat »
This was a HS Prom at a Car Dealership, May 18-2013. 2 DR250's and 4 T39 24" using 3012LF.
Currently Built:
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
doncolga
Re: DR250 and T39
#2 Post by doncolga »
Sounds really good man. :clap: How were you setup?...I'd guess you were able to do some boundary loading?
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
Lastcat
Re: DR250 and T39
#3 Post by Lastcat »
Thanks Don. Just the DR250's about 30' apart, up about 9'. Had the 4 T39's behind the left DR250. T39's stacked "V" style, without the plate. No corner or wall loaded. Bass was plenty. Used to use the V Plate at first, then started without it, to speed setup and tear down, except when I get into bigger rooms and outside, then I will add the V Plate.
This is what I use for Camera. Not the best on the Highs, but great on the Lows.
Currently Built:
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
Re: DR250 and T39
#4 Post by DJPhatman »
Lastcat wrote:...DR250's about 30' apart, up about 9'.
I wanted to ask you about why you had your tops so high? Were the highs fading in and out all over the room, like they were in the video?
Disco-inferno
Re: DR250 and T39
#5 Post by Disco-inferno »
Lastcat wrote:This is what I use for Camera. Not the best on the Highs, but great on the Lows.
I wanted to ask you about that, the highs sounded a little harsh in the video. Apart from that I think this is a very nice and clean sounding setup. :clap:
Lastcat
Re: DR250 and T39
#6 Post by Lastcat »
9' is fine. On the left, it was actually over the top of a partition, you can barely see. Highs fading? Not at all, Flip Up Camera is not the best with the highs, but great with the lows.
Currently Built:
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
Re: DR250 and T39
#7 Post by Tom Smit »
Sounded pretty good!
