can someone give me a proper response to this
5meohd
#1 Post by 5meohd »
"Wood for enclosure should be MDF as it does not resonate like a pressed plywood. You would have greater output and more accurate detail with MDF"
thanks
4 T60's
2 Danley Sound Labs SH69
Ashley Protea
QSC PLX2
Crown CDi
Re: can someone give me a proper response to this
5meohd wrote:"Wood for enclosure should be MDF as it does not resonate like a pressed plywood. You would have greater output and more accurate detail with MDF"
"Bullshit." Paul Klipsch.
5meohd
#3 Post by 5meohd »
thanks! but seriously.. any links or long winded discussion would be great, I actually don't know much about material resonances and stuff, curious.
4 T60's
Ashley Protea
QSC PLX2
Crown CDi
#4 Post by Bruce Weldy »
5meohd wrote:thanks! but seriously.. any links or long winded discussion would be great, I actually don't know much about material resonances and stuff, curious.
Why waste your time arguing with an idiot? You won't win and it brings you down to their level.
Instead, just turn the tables and ask if he can prove his statement. Let him do the research. And other than his own opinion, I doubt he'll find much else to back up a statement like that.
#5 Post by Grant Bunter »
While MDF is described as suitable for some of Bill's designs, it's a PITA in lots of ways.
It's heavy, hates water and the high strength aldehyde glues used to manufacturer it are a problem when cutting it. I hate the stuff.
Bill's bracing in ply made cabs takes out cab resonance...
5meohd
#6 Post by 5meohd »
"Speaking from a strictly sound quality standpoint, mdf will absolutely sound better"
4 T60's
Ashley Protea
QSC PLX2
Crown CDi
miked
#7 Post by miked »
Grant Bunter wrote:While MDF is described as suitable for some of Bill's designs, it's a PITA in lots of ways.
I was going to post a very similar reply, so I'll just second Grant's. :) As long as a cabinet is air-tight AND has the right bracing, that's all that matters.
#8 Post by Grant Bunter »
5meohd wrote:"Speaking from a strictly sound quality standpoint, mdf will absolutely sound better"
Good grief!
Same old same old, just opinion and seemingly not proven.
If it's not a measured increase, it's just subjective opinion.
It would make the same sonic difference as $2000 RCA interconnects and $500/metre/yard speaker cable.
I mention these because the people who buy them swear it makes a difference to SQ.
If MDF is so good for cabs, why isn't every cab in the world (since MDF was invented) made from MDF?
Surely all those people who don't build from MDF are in the majority, and that should tell you something...
#9 Post by Bill Fitzmaurice »
No, it won't, but as others have said there's nothing to be gained in arguing with an idiot. As for the actual benefits of MDF, it's cheap and it veneers well. That's it.
Michael M
#10 Post by Michael M »
I heard MDF is so good for cabs, you can turn it to 11. :wink:
David Raehn
#11 Post by David Raehn »
If the wood of your speaker cabinet is resonating, something must be amiss. The transducer should make the air move, not the wood....
BFM rig:
6 OT12
4 T48
4 WH8
Other:
56 box Electrotec LabQ rig
Way too many cables
:noob:
5meohd
#12 Post by 5meohd »
can someone please give me some examples. this dude is actually trolling hard enough to post directly on my facebook wall which is currently a MEGA networking engine for this new "business" I just invested in. I actually tried to look into it and it does seem that a LOT of super hi fi loudspeakers are indeed MDF.
4 T60's
Ashley Protea
QSC PLX2
Crown CDi
MissileCrisis
#13 Post by MissileCrisis »
Here is an example of a well respected (within it's market) loudspeaker using plywood. http://www.prosoundweb.com/product/topi ... e_powered/
See the electrovoice live-x series.
Also, if you look into actual high end subs/cabs where the cabinet is already massive the reason they would go MDF is for price, when it's lifted by a forklift they can get away with 1 inch thick mdf panels. Regardless, +1 to what bill said, proper bracing eliminates cabinet vibration, not thicker wood... Example : my mfw-15 vibrates a heck of a lot more than my T39 (mdf vs ply).
2 x TLAH
1 Titan 39 (lab 12, 15 inch)
1 Tuba 60 (lab 12, 20 inch)
SLA Center
2 x Mini MLTP subwoofers
1 x 212 TH (custom)
2 x Mini-Karlsonators
Owned, but not built
2 x Jack 12 (2512, melded)
Michael Ewald Hansen
#14 Post by Michael Ewald Hansen »
5meohd wrote:can someone please give me some examples. this dude is actually trolling hard enough to post directly on my facebook wall which is currently a MEGA networking engine for this new "business" I just invested in. I actually tried to look into it and it does seem that a LOT of super hi fi loudspeakers are indeed MDF.
Yes, a lot of hifi speakers are indeed MDF, but the only reason why that is so, is that its very easy to sculpt and it paints and veneers very easy.. The weight of it is just a trick to make people believe its much better quality because it weighs a ton and also, the very thickness of it is to make up for bad and faulty speaker design with inadequate bracing..
There's a reason professional and high performance speakers from pretty much all brands are made out of plywood - its much much more durable and weighs way less, albeit at a cost, because good quality plywood is way more expensive than MDF..
MDF is ok to use in a speaker that is put in a living room and never moves, for all other purposes I wouldnt hesitate to say that plywood is in any way superior..
Authorized Builder - Denmark
88h88
#15 Post by 88h88 »
I was gonna say what Michael did ^^
