Wireless Mics
doncolga
Wireless Mics
#1 Post by doncolga »
Hey all,
I have the Shure Performance Gear wireless mic and lav. It's shaky...I've had it cut out on pastors in the middle of wedding ceremonies, but it usually gets by OK. Any suggestions on an upgrade? I was considering the Audio Technica System 10...
Thanks!
Donny
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
byacey
Re: Wireless Mics
#2 Post by byacey »
Look towards Sennheiser...
T48s
WH8s
SX212
Gauss
Re: Wireless Mics
#3 Post by Gauss »
Working sound at church, one guy did some research on why our expensive wireless units were dropping out, and he said we need to move them away from our power strips. Try moving your receiver farther from your rig. What have you got to lose?
BASS: Combo Amp & Titan39
netwerks
Re: Wireless Mics
#4 Post by netwerks »
sennheiser g3 rock solid. Look on ebay.
Doug Hart
Re: Wireless Mics
#5 Post by Doug Hart »
I have used several of the PG series mics without any trouble. Don't care much for the sound of them tho.
We are in the process of replacing all of our mics with the Line6 V75's
We have 5 so far (4 handhelds and one lav) and we love them.
Doug Hart, Owner
dB Pro Audio
http://www.hartdesignsetc.com
Re: Wireless Mics
#6 Post by AntonZ »
Does anyone have experience with the AKG WMS 40 wireless mics? Our kids' school has limited budget and is looking to upgrade their old, cheap and most of all crappy wireless mics.
doncolga
Re: Wireless Mics
#7 Post by doncolga »
Gauss wrote:Working sound at church, one guy did some research on why our expensive wireless units were dropping out, and he said we need to move them away from our power strips. Try moving your receiver farther from your rig. What have you got to lose?
I'll try this first. I've actually got it in the rack, but it's attached to the shelf with some velcro so I pull it out when I need to. The times I had dropouts it was in the rack, when no dropouts it was just on top, so I'll make a point to move it as far away as practical.
Donny Collins
byacey
Re: Wireless Mics
#8 Post by byacey »
Years ago a client was complaining about drop outs on his junky wireless system. I recommended :idea: he plug the receiver into a long XLR cable and a long AC extension, and carry the RF handheld mic in one hand, and the receiver in the other as he moves around. He wasn't amused.
T48s
WH8s
SX212
byacey
Re: Wireless Mics
#9 Post by byacey »
The best thing to do is place the receivers near the stage, well away from any metal objects. Any nearby metal reflects the RF energy and creates null points due to phase cancellation, just like speakers. This is the prime cause of dropouts, even with diversity units.
Keep in mind many walls have tin studs, another source of multipath reflections.
T48s
WH8s
SX212
BrentEvans
Re: Wireless Mics
#10 Post by BrentEvans »
doncolga wrote: I have the Shure Performance Gear wireless mic and lav. It's shaky...I've had it cut out on pastors in the middle of wedding ceremonies, but it usually gets by OK. Any suggestions on an upgrade? I was considering the Audio Technica System 10...
System 10 is 2.4ghz, so you're susceptible to interference from all kinds of things (wifi on everyone's cell phone is a big one). That line is marketed to people who don't know any better.
Shure PG is a 10mw transmitter, and with poor frequency agility and internal antennas you will have problems in many areas. With 10mw units, you simply must put the receivers on stage, as the "reliable" range is 25-50 ft.
Don't spend any money to upgrade unless you go to 30mw transmitters, like the Sennheiser EW100 series (rebates are available on these until the end of May). Call Cal at Full Compass (x1119) and tell him I told you to call.. you'll get a great price plus the rebate on top of that. The unit you want is the EW110G3LE (if you can still find it) or the EW112. These are 30mw all metal units with the ME2 lav capsule rather than the more common ME4 (which sounds horrible). For a little less money than the EW112 you can get the Audio Technica ATW3131BC, which is a great 30mw unit too, with a few less features than the EW112. It has the AT 831 capsule which sounds great, and the bodypack is the sturdiest plastic I've ever worked with. If you're stuck on Shure, you have to go to at least the SLX before you get 30mw, and the bodypacks are much flimsier than the AT or Sennheiser.
doncolga
Re: Wireless Mics
#11 Post by doncolga »
I may consider a snake instead and put the receiver on the wedding ceremony end of it for the time being, as I don't have a snake anyway and could use one. I need to be able to have multiple mics and the lapel for vocalists, readers and the pastor (the only one who really needs the wireless).
Donny Collins
doncolga
Re: Wireless Mics
#12 Post by doncolga »
Well how timely did this turn out to be...
Tonight I'm doing a class of 1963 reunion and they're doing LOTS of speaking...on the wireless handheld mic that's part of this little Shure PG rig. Receiver is away from the rack and so far it's been really good. Room is about 30X60 feet with about 100 guests. Woohoo! Sure glad I had it here. The house system was not usable.
Donny Collins
BrentEvans
Re: Wireless Mics
#13 Post by BrentEvans »
doncolga wrote: Room is about 30X60 feet with about 100 guests.
That's about what the PG line was designed for. Line of sight helps a lot.
doncolga
Re: Wireless Mics
#14 Post by doncolga »
Copy that...that's what I've had for the most part in here.
Donny Collins
doncolga
Re: Wireless Mics
#15 Post by doncolga »
Hey Brent,
I just pulled the trigger on the Audio Technica ATW3131BC. I've got numerous wedding ceremonies coming up and need an upgrade. Should I be able to get a handheld mic by itself to go along with this receiver?
EDIT: Just found a matching handheld transmitter. May be adding this soon.
Thanks!
Donny
Donny Collins
