SLA surround thoughts and musings
Ian Westwood
#1 Post by Ian Westwood »
Been thinking a little bit about SLA surrounds so knocked these up in AutoCAD. Interested in comments and opinions...
I definitely need more than one speaker in a box for the surrounds because of my receivers "all speaker stereo" mode for music.
This first one is my favorite so far.
Authorized BFM Builder
Michael Ewald Hansen
Re: SLA surround thoughts and musings
#2 Post by Michael Ewald Hansen »
You might wanna consider impedance, as 3 paralleled is 2.66ohm.. 4 is needed for 8ohm :)
Authorized Builder - Denmark
Ian Westwood
#3 Post by Ian Westwood »
D'oh, school boy error :noob:
Edit: Back home now.
3 woofers in parallel is 4.66 ohms because the impedance at 4kHz is 14 ohms for the GW-4028's
= 1/ (1/14 + 1/14 + 1/14)
= 4.6667 Ohms!
67baja
#4 Post by 67baja »
I would think 2 woof, 2 or 4 tweets would be plenty for the surrounds.
Ian Westwood
#5 Post by Ian Westwood »
2 of Each works. That comes out at 4 Ohms for the tweeters and 7 Ohms for the woofers.... which complies with Bills "try to keep the ratio of impedance's within 2:3" rule.
67baja
#6 Post by 67baja »
That 4.66 ohms is not the nominal impedance, only the resistance at 4k.
Ian Westwood
#7 Post by Ian Westwood »
Yep, that's (14 Ohms) what you use to work out the cross over values.
#8 Post by Michael Ewald Hansen »
Ian Westwood wrote:Yep, that's (14 Ohms) what you use to work out the cross over values.
I don't think you're getting what we're saying.. The impedance at 4khz is for figuring out your filter.. The woofers are still 8ohm nominally and that's 2.66 when you parallel 3..
Ian Westwood
#9 Post by Ian Westwood »
I get that... I'm looking at using 2 of each right now.
Oscillate
#10 Post by Oscillate »
The other thing is that the speaker line (lenght of the contiguous midwoofers)
needs to be at least 3 ft. (or thereabouts) in order to take advantage of an
arrayed configuration. If it's shorter than that and/or with the impedance
problems everyone is pointing out ...you may be better off building 2-ways
or MTMs for your surrounds.
anikun07
#11 Post by anikun07 »
I've been thinking about this too, and I was considering 4 of each driver. Placing two in parallel in a having those in a series. This would create an 8-ohm nominal impedance across four drivers. I suppose if I were to use the 2/3 rule, which I don't quite recall, but I'm assuming it's that the tweeters impedance is 2/3 of the woofer impedance, then maybe 6 tweeters with three in each parallel and wired into a series. I know 14-ohms is the "dead" (no signal/power) impedance but I think if 8-ohms is the nominal, then once power is going to the speaker that would end up closer to 8-ohms.
#12 Post by DJPhatman »
All of this is pointless. All there is in the surround channels is "ambient sound" which is not a lot of sound. There is no need to put anything more than a woofer and a tweeter on your surrounds. Point them at a wall to remove some "directionality". I point mine at the joint of a wall and ceiling.
DJPhatman wrote:All of this is pointless. All there is in the surround channels is "ambient sound" which is not a lot of sound. There is no need to put anything more than a woofer and a tweeter on your surrounds. Point them at a wall to remove some "directionality". I point mine at the joint of a wall and ceiling.
Not necessarily. Some DVDs are now mixed with specific content that can benefit from directionality and high output capability. I think MKtheater is now using DR200s over T39s for his surrounds. :shock:
But he's seriously nuts. :loler:
88h88
#14 Post by 88h88 »
Bill Fitzmaurice wrote:I think MKtheater is now using DR200s over T39s for his surrounds. :shock:
Yeah but in the best possible way... :chainsaw:
