I scanned through a bunch of "build" threads here before tackling the Titan 39, and found a huge base of useful tips and tricks; I've been a metalworking guy for ~40 of my (currently) 59 years, but despite inheriting a variety of woodworking tools have never taken any serious interest in it... 'til this project.
Really, you need little more than determination and a modest workspace to complete these plans... and not even much of the latter, as the photos will show. You absolutely don't need an arsenal of high-buck tools, or even an extra pair of hands (although that'd have been nice once or twice) to build the T39... some fresh sawblades should be considered a wise investment, though.
After deciding to build 24" wide I used Cutlist (http://www.delphiforfun.org/programs/cutlist.htm) to lay out the material usage for two 60" x 60" sheets of ½" BB plywood sourced from a local cabinet shop... in the end, I also cut a few final bits from two 24" x 30" pieces purchased from the local Woodcraft store (http://www.woodcraft.com/).
Basic cuts were made on the garage floor, using a circular saw and Home Depot guide:
...then squared/trimmed closer to plan sizes using my late-'50s ShopSmith table saw:
...which was also used for final-size trims. This old-as-me saw has perhaps 3/4 horsepower on a good day, so I went with a high toothcount/thin-kerf blade to reduce power demands.
One thing which didn't come with the saw, however was any sort of blade guard
...so extreme caution was the order of the day any time it was plugged in. Even with a better machine I'd wholeheartedly recommend a GRR-Ripper, which you can get (along with excellent service) from Leland at speakerhardware (http://www.speakerhardware.com/micro-jig-grr-ripper.php).
Once the pieces were roughed to size, and the panel orientation laid out it was a simple matter of following the plan step-by-step:
...over successive nights, leaving time for the PL Premium to do its' thing... nighttime temps were generally in the low-30°F range (January-February) so I didn't try to rush construction.
BTW another tool I'd recommend for sure (if you don't already have one) is a brad nailer... I picked up a -very- inexpensive (<$20) 18ga nailer from Hazard Fraught Tools:
http://www.harborfreight.com/18-gauge-b ... 68021.html
...and it never missed a beat as long as I used good-quality brads. This tool most definitely saved me time and numerous how-can-I-hold-this headaches.
Another evening or two, a couple more panels and pretty soon you're wrapping things up:
It's likely that either one of my sons, or my keyboard-player stepson will end up with the T39 at some point so I left a little 'easter egg' under the access panel explaining the setup:
...and will put something with the basics on the back near the connector. Speaking of which- I didn't have the foresight to plan that aspect out as well as I should have, and ended up surface-mounting (rather than flush-mounting) the connector... that necessitated nailing/gluing a guard piece around it for protection (can be seen in photo below) which wasn't the most elegant way to get from A to B. Ya live, ya learn.
DuraTex'ed a few coats (another learning curve, but great stuff!) and finished up mounting the furniture and handles yesterday...
Again, thanks to all here for the many informative threads across the site- to Leland at speakerhardware.com for his first-rate customer service- and to Bill, for extremely well-done and concise plans even a first-time woodworker can complete.
Regards,
Ed
