2x OTop 12 JArrays w/ melded tweeters
Jake Smith
#1 Post by Jake Smith »
These are the first tops I've built. I built a Tuba 60 several months ago, and that was my first step into BF speakers.
^ Tweeter jig for my radial arm saw.
^ OTop, generic 15" PA, Tuba 60
Some notes:
- Bill says to use 3/8" thumbscrews for the stands and brackets, but they're kind of expensive for what they are. So, I used cheap hex cap screws for now. I've considered adding these to them.
- The stand/bracket holes at the rear of the first cab were all 1.5 inches too far forward. I had add extra holes on one stand.
- I chose to go with the Delta Pro drivers for now. I may upgrade to a lighter driver in the future to complement the 1/4"-thick cabinet.
2 - OTop 12 JArray cabs
2 - Tuba60s (18" wide)
Re: 2x OTop 12 JArrays w/ melded tweeters
#2 Post by Grant Bunter »
Hi Jake,
Welcome to the forum from me!
Nice looking build to date.
Thanks for sharing :)
88h88
#3 Post by 88h88 »
If you can do so you should adjust the coils on your crossover to prevent crosstalk. They're both sat flat at the moment, stand the smaller one up and strap it down secure.
Nice clean build though!
#4 Post by Grant Bunter »
88h88 wrote:If you can do so you should adjust the coils on your crossover to prevent crosstalk. They're both sat flat at the moment, stand the smaller one up and strap it down secure.
Interesting you say that, I thought it could be further away from the driver also, like on one of the cab sides...
88h88
#5 Post by 88h88 »
Well that too, the ones in my bog standard OTs are sat in the bottom corner.
#6 Post by LelandCrooks »
Nice. The Jack lites are amazing.
Bas Gooiker
#7 Post by Bas Gooiker »
Really nice...
How is that plexiglass cover on the Tuba holding on?
Jake Smith
#8 Post by Jake Smith »
Bas Gooiker wrote:How is that plexiglass cover on the Tuba holding on?
Being that it's a half of an inch thick, it's solid!
#9 Post by Tom Smit »
Half way there! Good job so far! Waiting for the review, of course. :)
Spoon
#10 Post by Spoon »
Nice work!
2 OT12's 2512 CD
2 OT12's 2512 Melded Array
4 Titan 39's 30" 3012LF
4 Titan 39's 20" 3012LF
6 Wedgehorn 8's
1 Wedgehorn10
2 AutoTuba's 18" w/MCM 8"
https://www.facebook.com/pages/LSW-Lana ... 080?ref=hl
jswingchun
#11 Post by jswingchun »
I can't get over how cool the OT12 J-Arrays are. Seeing your thread makes me want to ditch my regular OT12s and build the new ones. Nice post!
Omni 10
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
Jake Smith
#12 Post by Jake Smith »
For those interested, I just weighed one of these without base/bracket attachments, and it comes in right at 35 lbs. That's using 1/4" Baltic birch construction and an Eminence Delta Pro 12 driver. The Delta Pro 12 weighs 17.9 lbs. If you were to use the neodymium-magnet-based mid-grade driver as suggested by Bill, the Deltalite II, which weighs just 6.8 lbs, you could make one of these cabs weigh in at about 24 lbs!
:shock:
Harley
#13 Post by Harley »
LelandCrooks wrote:Nice. The Jack lites are amazing.
To build...or listen to :mrgreen:
