Show off your jigs!
Bas Gooiker
Show off your jigs!
#1 Post by Bas Gooiker »
Following your build threads i've seen a lot of people using all kinds of clever "diy" jigs to easy up the build process. Using the search function of the site gives a whopping 945 :shock: results in just as many different build threads. Maybe its a good idea to get them all in one place. I am curious to see your favorite ones.
Re: Show off your jigs!
#2 Post by AntonZ »
You should start Bas, show us your jigs :)
Here's one of my favorites, the simple router circle jig. I make all my baffle cutouts with this one.
Cutting angles over 45 degrees on the table saw. Screwed on top of Bill's panel cutting jig. Cutting 60 degrees here.
Piezo test jig. One known good piezo, cup to hold an unknown piezo, compare response and phase. Connect to a transistor radio tuned between stations to feed noise.
Piezo array glue jig. Use with wax paper.
I'm also fond of the W-clamp jigs, have no pics of those though.
But it Hertz
#3 Post by But it Hertz »
My SLA template gives hole centers. Just drill through into the baffle.
I made it the exact size of the baffle and wrote all the measurements / some notes on the template so I don't have to work everything out again in the future. This way I can easily create a variation on this theme.
mr.lussier
#4 Post by mr.lussier »
Good to see you didn't forget the most important : the wine drinking jig
:loler:
Built : 2 x beta8 wedgehorn w/melded array
20'' wide t39 3012lf loaded
still can't decide on tops !
#5 Post by Tom Smit »
mr.lussier wrote:Good to see you didn't forget the most important : the wine drinking jig
:loler:
But only to toast the successful jig, of course. Right????!!!!
But it Hertz
#6 Post by But it Hertz »
I enjoy a little tipple while woodworking, especially at a milestone 8) but I stay off the table saw or anything that could take a chunk of me off once i have had a drink!!
Sooo much good wine here in CA.
#7 Post by AntonZ »
Oh, and I routed the WH8 logo in my other Wedgehorn, the one I bought from DJPhatman long ago. It is the old model, can still hardly believe the new model is yet a better vocal monitor.
The template jig.
Routed logo in the cab.
I will apply a fresh coat of Warnex to the entire cab, then I will have two identical wedges. Here's the other wedge.
#8 Post by Bruce Weldy »
Here's some .....
Oh shoot! :confused: You said JIGS.... :oops:
88h88
#9 Post by 88h88 »
GEEEEEEEEEEEEEEEET YOUR JIG OUT FOR THE LADS, FOR THE LADS............
:shock:
But it Hertz
#10 Post by But it Hertz »
I appreciate an almost perfect circle. These are no exception.
maxo
#11 Post by maxo »
Bruce. i love those Jigs.. !!!!
It is not the bananas but the monkey
Scott Brochu
#12 Post by Scott Brochu »
Bruce did you make those or are they fresh out the box? :P :mrgreen:
I see you gave them a coat of Duratex.....I would of left them a natural finish. :mrgreen:
Drumming is a way of life.
ME LIKE TO HIT THINGS!
biggerrigger
#13 Post by biggerrigger »
Bruce what exactly are you doing posting pics of my GF on BFM? :cop:
4-25" Lab12 loaded T39's
2-DR250's Melded array
2-DR250's Flat array
#14 Post by Bruce Weldy »
biggerrigger wrote:Bruce what exactly are you doing posting pics of my GF on BFM? :cop:
Better than posting pics of your BF on GFM, right?
Harley
#15 Post by Harley »
Bruce Weldy wrote:hmmm......you boys downunder are starting to scare me a little.. :conf:
Bruce Weldy wrote:Here's some .....
Who's scaring who here Bruce? :mrgreen:
