Hello, I´m writtig from South America
I´m thinking about building a pair of DR 280, but there are no Eminence drivers available here
I´ve been searching for drivers with similar parameters and found a B&C one, but I´n not really sure if it can work well
I would appreciate if anyone can help me with this issue
Thanks
Driver B&C 12 HPL 76
Specifications
Nominal Diameter 320 mm (12 in)
Nominal Impedance 8 Ω
Minimum Impedance 6.7 Ω
Power Handling
(50 - 500 Hz)
Nominal1 350 W
Continuous Program2 700 W
Sensitivity (1W/1m)3 99 dB
Frequency Range 50 - 3500 Hz
Voice Coil Diameter 76 mm (3 in)
Winding Material Aluminium
Former Material Glass Fibre
Winding Depth 17.5 mm (11/16 in)
Magnetic Gap Depth 10 mm (3/8 in)
Flux Density 1.15 T
Magnet Material Neodymium Inside Slug
Thiele & small parameters
Fs 49 Hz
Re 5.7 Ω
Qes 0.26
Qms 2.5
Qts 0.25
Vas 91 dm3 (3.2 ft3)
Sd 522 cm2 (80.9 in2)
η0 4.1 %
X max ± 4 mm
X var ± 5.5 mm
Mms 43 g
Bl 17.3 T·m
Le 1.5 mH
Driver for Dr 280
Re: Driver for Dr 280
This link also shows an SPL chart which will help people advise you:
http://www.bcspeakers.com/CPD/product_p ... 0000000063
If I was going to go to the effort to build a DR280, I would be putting recommended drivers in it...
Thank you Brant
I think the same as you, but unfortunately the recommended driver is not available here...
Where in South America are you?
Eminence USA tells me that there is a distributor in Argentina.
Todomusica S.A.
AV. Warnes 2280
C.A.B.A. C1427DPO +54 (11) 4555 3434 eliseo@todomusica.com.ar
Todomusica S.A.
AV. Warnes 2280
Grant, thank you for the information
The problem here is that the Goverment has limited al the imported articles and there are a lot of stores that do sell eminence, but no one has stock
I have just called Todo Musica (didn¨t hear about them before) and they told me they are out of stock, but may be they will receive some units by year end, so good news I think...I´ll wait
Than you!
Than you!
It does not have a rising response in the midrange.
