Instrument Mics
- jswingchun
Instrument Mics
I know the Behringer XM8500 is thought of as a solid low budget replacement for an SM58. Anybody have any thoughts on a similar bargain on a decent instrument mic? I'm thinking mostly for guitar cabs. I had an SM57 fail and I would like to pick up a couple of replacement mics.
Omni 10
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
Re: Instrument Mics
The Carvin 57 knockoff works well.
Re: Instrument Mics
I'm surprised you had an SM57 fail. Aside from the plastic windscreen shell, these mics will withstand a lot of abuse. In fact, I've heard stories that the sister mic, the SM58 could be used as a shingle hammer to do a roof, and then later used on stage with no ill effects.
T48s
WH8s
SX212
T48s
WH8s
SX212
Re: Instrument Mics
The Audix i5 is a popular replacement for, or supplement to, the SM57. I've used one live but don't own any, the sound as good as the 57 but I can't comment on the durability.
You could always just buy more 57s, most companies I've worked with/for have dozens of them in the mic cabinet.
Re: Instrument Mics
If the housing of your 57 is still ok, get a trashed body one cheap of da bay and swap out the capsule/head. Much cheaper than buying a replacement unit.
I've heard it said that drummers can pop a 57 capsule with one perfectly placed tap. That would be the drummers who thrash IMO, I can't recall hitting a mike in my lifetime of playing.
ISK (if you can find them where you are) make a 57 rip off, model number DM-57. According to reviews it out57's a 57, about 1/3 of the RRP.
Re: Instrument Mics
I'm quite happy with XM8500 for guitar cab. Guitar player is welcome to bring his own, yeah right!
Re: Instrument Mics
JTS also makes a 57 and 58 knock off; essentially a carbon copy, visually and sonically.
T48s
WH8s
SX212
T48s
WH8s
SX212
Re: Instrument Mics
I use the gls audio es57. There have bee several occasions where I had a sm57 on something and switched it out because the es57 sounds a good deal better. A little more open pickup pattern from my experience, but not in a bad way. I love it for acoustic instruments.
$85 for a three pack and their mic cables are a good deal too. Good ends. Not neutrik, but still very good.
Benj
Benj
http://www.fofg.org
Peavey and Madisound Dealer
http://www.fofg.org
Re: Instrument Mics
jswingchun,
sorry to sidetrack, but Benj you have some serious spelling errors on your page(s)
- jswingchun
Re: Instrument Mics
Thanks for all the suggestions guys, didn't get back earlier cuz it was a gig weekend. I will check into them!!
Omni 10
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
- jswingchun
Re: Instrument Mics
The little plastic circle on the top of the capsule detached, breaking the tiny little copper wire that attaches from it to the capsule.byacey wrote:I'm surprised you had an SM57 fail. Aside from the plastic windscreen shell, these mics will withstand a lot of abuse. In fact, I've heard stories that the sister mic, the SM58 could be used as a shingle hammer to do a roof, and then later used on stage with no ill effects.
Omni 10
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
- jswingchun
Re: Instrument Mics
Wow! The reviews on the GLS Audio ES-57 are great! I read a sh*t ton of reviews and only saw one bad one. I think I'm going to order one (or the three pack) to try.Benj Ross wrote:I use the gls audio es57. There have bee several occasions where I had a sm57 on something and switched it out because the es57 sounds a good deal better. A little more open pickup pattern from my experience, but not in a bad way. I love it for acoustic instruments.
Benj
Omni 10
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
Re: Instrument Mics
I was hesitant to buy cheap mics, but these perform well. I think you'll be happy with them.
@ grant: If you are referring to my posts, fast typing on an iphone. My apologies. It seems, though, that you are referring maybe to my website? It needs a lot of work still and yes I am aware that it has not been proofed very well. Thanks for reminding me. It got shunted to the back burner while working 7 days a week all summer.
Benj
Benj
http://www.fofg.org
http://www.fofg.org
Re: Instrument Mics
Hey Benj,
No biggy if the spelling errors are here, I was only worried about the odd one or two on your website...
Re: Instrument Mics
Thanks Grant!
Thanks Grant!
http://www.fofg.org
http://www.fofg.org
