Huge sound systems
Huge sound systems
Have you guys seen this?
http://www.youtube.com/watch?v=4ahkb8Nr ... re=related
We can only imagine having a BFM system of similar proportions and how much louder and more sensitive it would be! Surely we can pick better music too.
Re: Huge sound systems
My wife and I were in the Philippines to visit her family in July 2005 and they had a local DJ for her birthday party. All the boxes looked DYI and it was one giant stack probably 16' x 12'. It was quite fun watching the setup.ryan222h wrote:Have you guys seen this?
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
Bas Gooiker
ehh... less is more....
nop... this is more!!
This looks like the guy needs to compensate something.
- BrentEvans
These rigs are designed to look massive, not sound great. A much smaller BF system, properly designed and deployed, could certainly blow that rig away in both sound quality and SPL. However, at a certain point it becomes a bit of a moot issue, as you reach the sensitivity barrier.
That said, a BF system of similar size in similar deployment would sound about the same. Cancellations, interference nodes, and sheer volume would see to that.
But it Hertz
I think the camera phone dude filmed exactly the same as I would react. Just stand there looking back and forth trying to figure out why you would do this.
Bas Gooiker wrote:ehh... less is more...
and where is the close up of the power amps driving that masive cabs
i counted close to 70 subs
so i will drive 4 with a crown MA-5002 VZ who on the spec sheet is rated at 2kw at 4 ohms on stereo mode
so i hook up 2 cabs per channel
70/4 equals like to 17 or 18 amps , just for the subs
the full range and high cabs i dont know...
so at least those guys need to have 18 amps for the subs with the crown specs...
that i really doubt
that i really doubt
It is not the bananas but the monkey
- BrentEvans
The engineering knowhow that set up a setup like that would probably think it A-OK to run amps full bore at 2 ohms. That halves the amp count to 9. If they knew how to series-parallel wire (and had amps of sufficient voltage swing) the whole thing could be run on half that many (4 or 5 for subs). Technically, with some creative wiring and stupid powerful amps, you could run all of the subs on one or two amps.maxo wrote: so at least those guys need to have 18 amps for the subs with the crown specs...
that i really doubt
PersonallyBrentEvans wrote:The engineering knowhow that set up a setup like that would probably think it A-OK to run amps full bore at 2 ohms. That halves the amp count to 9. If they knew how to series-parallel wire (and had amps of sufficient voltage swing) the whole thing could be run on half that many (4 or 5 for subs). Technically, with some creative wiring and stupid powerful amps, you could run all of the subs on one or two amps.maxo wrote: so at least those guys need to have 18 amps for the subs with the crown specs...
that i really doubt
i prefer modular systems
in the case that some monkey misswire or short my cables i loose a couple of cabs
instead of the whole wall or half of it if i run only 1 or 2 amps
is better to have some boom than nothing at all in case of havoc
imho
- BrentEvans
maxo wrote: Personally
imho
I didn't say it was recommended... just possible.
I just expressed my very own personal opinionBrentEvans wrote:maxo wrote: Personally
imho
there is many ways to skin a cat
but your approach is very elegant
