Freud 50-118 Top Bearing Flush Trim Router Bit - vibration
But it Hertz
#1 Post by But it Hertz »
I have this router bit: http://www.amazon.com/gp/product/B002IP ... 01_s00_i00
But it seems like it is out of balance. None of my other bits cause vibration.
I just received a replacement bit and it is just the same.
The vibration causes the router (Dewalt DW618) to wonder around.
Is this normal or is there a bad batch? For $35 and the Freud name I'd expect pretty much perfection!
Re: Freud 50-118 Top Bearing Flush Trim Router Bit - vibrati
#2 Post by Tom Smit »
Do the other bits have a top bearing, as well?
#3 Post by Radian »
....and how much are you trying to cut with it in a single pass?
But it Hertz
#4 Post by But it Hertz »
This is before I even try using it to cut!!! I'm talking about "just revving it up in free air"... NOT cutting wood!
It feels like I might be doing the router harm by running it. If you let it go it wanders across the bench!
I have a mixture of cheap & nasty & Freud. Some have bearings on top, others at the bottom. They all seem OK.
#5 Post by Tom Smit »
Weird.
Dunno.
Bad batch???
But it Hertz
#6 Post by But it Hertz »
Yeah. It has to be! I'll try another brand for this type of cutter. I like Freud, but only because the do good saw blades IMO.
I'm pretty much flying blind as far as the router bits go.
I'm like that: I find a supplier or brand that I like and stick with them for years!
#7 Post by Tom Smit »
Frued typically is good stuff, from what I've heard. YMMV.
#8 Post by LelandCrooks »
Scoot the shaft farther into the collet. And it's a Dewalt.
But it Hertz
#9 Post by But it Hertz »
LelandCrooks wrote:Scoot the shaft farther into the collet. And it's a Dewalt.
I put the bits all the way in and then back out 1/16 inch as per the Dewalt instructions. I think I just need to try another manufacturer of bits.
Harley
#10 Post by Harley »
But it Hertz wrote:I have a mixture of cheap & nasty & Freud. Some have bearings on top, others at the bottom. They all seem OK.
Have you run those others AFTER the Freud? If not, I would do that. You may just have a bit of crap in the collett somewhere putting the bit a few thou out of centre. At the high revs of a router, that will make it wobble.
Also it just may be coincidental that the bit change has struck the time the DeWalt Router bottom bearing is showing wear.
#11 Post by LelandCrooks »
Plus it's 1/4 shank with a very long cutter. They tend to chatter if you crowd them or are removing quite a bit of material. If your dewalt has a 1/2 collet, buy nothing else. Huge difference.
Sorry about the previous post, my tool snobbery was showing. I just hate the yellow stuff.
