Speaker Wire
Speaker Wire
I'll start by saying I did try the search funtion.
What wire is everyone using to make thier own speakon wire?
Where is everyone getting thier bulk 12g at.
What price can I expect (figuring $.75/ft-$1.00/ft?)
Re: Speaker Wire
I got some long ass instrument cables from ebay in .12, clipped off the ends and cut 'em to length. They're not the highest quality cables, but they're sufficient.
SLA Pro x 2
Yamaha S112V x 1
QSC RMX 2450
dbx Driverack PA
SLA Pro x 2
Yamaha S112V x 1
QSC RMX 2450
dbx Driverack PA
- Rune Bivrin
Re: Speaker Wire
If that's really instrument cable, i.e. shielded you're just lucky they haven't melted on you. If it's actually speaker cable you're probably ok.Dan30 wrote:I got some long ass instrument cables from ebay in .12, clipped off the ends and cut 'em to length. They're not the highest quality cables, but they're sufficient.
For the OP, what you should get is rubber insulated two-conductor cable. Gauge dependent on length, but generally 16-14 should be sufficient.
In build order:
O12 with no tweeter.
3 x WedgeHorns.
2 x Jack 10 without tweeters.
2 x DR250.
2 x 16" T39
1 x Tuba 24
2 x SLA Pro (sort of...)
3 x WedgeHorns.
2 x DR250.
2 x 16" T39
1 x Tuba 24
Re: Speaker Wire
I hope you don't really mean instrument cables, which should never be used as speaker cable.Dan30 wrote:I got some long ass instrument cables
OP, 12ga is usually overkill. Use this to figure out the gauge you need:
http://www.bcae1.com/images/swfs/speake ... istant.swf
Type SJ cable works very well, is inexpensive and available just about everywhere.
Re: Speaker Wire
I got a bunch of 14 ga off ebay a while back and I've been very happy with it. Great learning experience for me.
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
Re: Speaker Wire
While some consider 12ga overkill...and it may be in some cases, I've always tried to make sure whatever I build will handle any situation.
I always use 12ga for every length - and I like the way it looks and feels too.
Re: Speaker Wire
Thanks for all of the replies! Nifty calc Bill!! So it looks like 14g should suffice for all of my needs (power(50 volts max)/length(50ft)). I'm looking at awcwire.com and I can get 250ft for $132... .52/ft for 14/2 is even better than I was expecting!
Re: Speaker Wire
If you're looking for specifics, I've researched instrument and mic cables and for the price (& quality), I've stuck with Canare. They've handled getting crushed with equipment thanks to the braided shields.
That said, I've done speaker cables with the 4s8 and 4s11. 8's are really nice and are now my main cables. Also made some lengths for my monitors in this guage. I made the 11's first, and now use them only for larger stages, which we hardly do. They're heavier for sure, and I'm lazy, hence my move to Jack Lites and Crown XLS.
Wedgehorn 6 (x2)
Jack 110 Lites (x2)
XF212 (Egnater style)
DR200 ASD (Yes! Finally!)
Jack 110 Lites (x2)
Re: Speaker Wire
I like the feel and weight of 12 ga myself, and fits very good with Speakon Ends.
http://www.skycraftsurplus.com/122sjoowpowercord.aspx
http://www.skycraftsurplus.com/124sjoowpowercord.aspx
Currently Built:
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
Re: Speaker Wire
+1 I prefer 12 gauge for speaker wire. I used 10 gauge for my extension cords.Bruce Weldy wrote:While some consider 12ga overkill...and it may be in some cases, I've always tried to make sure whatever I build will handle any situation.
Re: Speaker Wire
I could see that...very heavy duty look and feel.Bruce Weldy wrote:While some consider 12ga overkill...and it may be in some cases, I've always tried to make sure whatever I build will handle any situation.
Donny Collins
Re: Speaker Wire
+1 Same here.DJPhatman wrote:+1 I prefer 12 gauge for speaker wire. I used 10 gauge for my extension cords.
Currently Built:
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
Re: Speaker Wire
not much of a price difference for this stuff! Thank you for the link!Lastcat wrote:I like the feel and weight of 12 ga myself, and fits very good with Speakon Ends.
Re: Speaker Wire
Actually its the type of cable. SJOOW is a better jacket. At awcwire you would pay $1.08 a foot for 250'. At Skycrafts $.61 a foot for 250'. And you will find that they fully fit with Speakon Ends. One thing I try to avoid is small thin wire with Speakon Ends. SJOOW will allow a nice tight fit, nothing getting in.brinandi wrote:not much of a price difference for this stuff! Thank you for the link!Lastcat wrote:I like the feel and weight of 12 ga myself, and fits very good with Speakon Ends.
As many times as you wrap and unwrap your cables, throw them in a box, pile them up, people walking on your cables (which I never allow) you will find SJOOW is a more durable grade.
Currently Built:
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
Re: Speaker Wire
I've been using trailer cable. It's considerably cheaper, coils up nicely, still very flexible even at low temperatures and has a tough outer jacket.
http://www.google.ca/url?sa=t&rct=j&q=% ... _g&cad=rja
T48s
WH8s
SX212
T48s
WH8s
SX212
