SLA Pro LPF
djtecthreat
SLA Pro LPF
#1 Post by djtecthreat »
Mods, I don't see a section for the SLA series, so forgive me if this is the wrong place to put this, and feel free to move it elsewhere.
I'm getting ready to build some SLA pro's and as I read the plans I notice there is a section that breaks down the LPF's for the other SLA's, but not the SLA pro's. There's only a piezo filter section.
What should I do here? I will be running the recommended driver compliment.
Thanks,
Jim
DJ TecThreat
-Building-
8 More T48's
-Built-
4 SLA Pro's
Re: SLA Pro LPF
#2 Post by AntonZ »
I'm glad you brought this up, as I've been looking into the same thing the last few days. Thinking of building some kind of SLA's, still looking into affordable driver options over here in Europe. There's some smaller drivers (4") that I might use a larger number of, like 9 high. But these smaller drivers play quite a bit higher than the regular 6" SLA-pro drivers. That would probably require LPF in order to keep them out of the piezo bandwidth. Perhaps I would need to rise the pizzer HPF as well.
Sorry, no advice to offer to you Jim, but awaiting eagerly what others come up with.
BassMe
Re: SLA Pro LPF
#3 Post by BassMe »
djtecthreat
Re: SLA Pro LPF
#4 Post by djtecthreat »
I'm guessing there's some confusion here, let me clarify.
I'm speaking about the LPF that goes on the woofers, more specifically the internal crossover. I need a diagram for this, there are included diagrams for the other models, but not the SLA Pro.
DJ TecThreat
-Building-
8 More T48's
-Built-
4 SLA Pro's
Re: SLA Pro LPF
#5 Post by CoronaOperator »
I think Bill mentioned that the recommended alfa 6a's natually roll off on their own and therefore don"t need a LPF on them.
Re: SLA Pro LPF
#6 Post by Tom Smit »
djtecthreat wrote:.
Thanks,
Jim
That is the only answer.
Re: SLA Pro LPF
#7 Post by LelandCrooks »
There isn't one.
djtecthreat
Re: SLA Pro LPF
#8 Post by djtecthreat »
Interesting. Figured they would need it.
That being said, what if I built them with the Dayton driver that everyone talks about? Would I then need a filter or will the Dayton's roll off as well.
DJ TecThreat
-Building-
8 More T48's
-Built-
4 SLA Pro's
Re: SLA Pro LPF
#9 Post by AntonZ »
Compare spec sheets. You can download them as PDF documents from the manufacturers' websites.
To me it seems response of both the Alpha 6 and the Dayton 6 drop sharply from about 4kHz up. They look pretty similar in that respect. The more knowledgeable may confirm or kick me :cowboy:
