Page 1 of 2
				Brickwall limiter options?
				Posted: Tue Jul 24, 2012 3:02 pm
				by Razor
				What else is out there for brickwall-limiting besides the Behringer DCX2496 and DBX Driverack 260? Just curious. Anything under $300?
				Re: Brickwall limiter options?
				Posted: Tue Jul 24, 2012 3:25 pm
				Razor wrote:What else is out there for brickwall-limiting besides the Behringer DCX2496 and DBX Driverack 260? Just curious. Anything under $300?
While some say the dbx PA or PA+ doesn't have brickwall limiting - I've never been able to get the voltage to go past my limit even when shoving the master fader all the way to the top of the red.
				Posted: Tue Jul 24, 2012 3:40 pm
				by Razor
				Bruce Weldy wrote:Razor wrote:What else is out there for brickwall-limiting besides the Behringer DCX2496 and DBX Driverack 260? Just curious. Anything under $300?
Does that include maxing out the input sensitivity on your amp?
I don't honestly think I need anything more than the dbx Driverack PA+ or PX. Just feel like I'd sleep better at night with a brickwall limiter.
				Posted: Tue Jul 24, 2012 4:25 pm
				by wallywally
				Any compressor that has 20:1 or higher ratio and 0ms attack is considered a brick wall limiter. That covers almost every modern compressor.
I seem to recall the reason the dbx wasn't considered a brick wall was because it didn't have the 0ms attack. Although I read that a long time ago and I'm not getting any younger so YMMV.
				Posted: Tue Jul 24, 2012 4:26 pm
				Razor wrote:Bruce Weldy wrote:Razor wrote:What else is out there for brickwall-limiting besides the Behringer DCX2496 and DBX Driverack 260? Just curious. Anything under $300?
My amps are ALWAYS wide open.  Too much room for error any other way.  Last Saturday, I was running a rock band outside and the limiter was kicking in occasionally on the kick drum....
I've played 'em outside several times at full tilt and have never blown anything up.  I do give myself some room though.  I'm limit the 3012LFs at 56 volts instead of the allowed 60.
I wouldn't spend the extra money unless you really need the additional features of a 260.
				Posted: Tue Jul 24, 2012 5:17 pm
				by Grant Bunter
				The BBE DS24 will be under $300, you may find one used cheaper
The newer model BBE DS26 is under $300 new.
There are other brands as well...
				Posted: Tue Jul 24, 2012 6:24 pm
				by Razor
				I figured the dbx PA+/PX would be enough, was just being paranoid. Thanks for the reassurance.
				Posted: Tue Jul 24, 2012 6:32 pm
				by Ryan A
				I use the BEHRINGER ULTRAMIZER PRO DSP1400P. You can get them for less than $100.
				Posted: Tue Jul 24, 2012 6:57 pm
				by Grant Bunter
				ryan222h wrote:I use the BEHRINGER ULTRAMIZER PRO DSP1400P. You can get them for less than $100.
I see that has brick wall limiting, but it's not also a crossover with HP and LP though is it?
				Posted: Wed Jul 25, 2012 1:54 pm
				by SirNickity
				I think his intention
was to use the DriveRack with an additional limiter, to achieve a wall of bricks.
				Posted: Wed Jul 25, 2012 3:37 pm
				by Vert
				Get a good second unit, AVC2 or Drawmer sp0102
				Posted: Wed Jul 25, 2012 5:53 pm
				Vert wrote:Get a good second unit, AVC2 or Drawmer sp0102
He's looking for something cheap.....
A used driverack will do everything you need.  Don't fret.
Even though there have been posts about the driverack not being a brickwall limiter - I've yet to see anyone post that they've blown a speaker while using one.
				Posted: Wed Jul 25, 2012 8:01 pm
				by Ryan A
				Grant Bunter wrote:ryan222h wrote:I use the BEHRINGER ULTRAMIZER PRO DSP1400P. You can get them for less than $100.
It's not designed to be a crossover, but it will perform that function as well (either broadband high pass or low pass). There's no info about what the slope is on it, though. I suspect its 12db or less per octave.
				Posted: Tue Jul 31, 2012 1:17 pm
				by djtrumptight
				so i have a chance to buy a Driverack PA+ FOR $200,brand new still in the box.I briefly looked in the manual online and didn't see anything about high pass and low pass filters.I plan to use this with my T-39's and am wondering if i should buy this or just buy another DCX 2496.What do u guys think ?
				Posted: Tue Jul 31, 2012 1:57 pm
				by SirNickity
				There's a crossover.  You can set HP/LP on the L, M, H outputs.  So yes -- you can use it with T39s.
