Brickwall limiter options?
Razor
#1 Post by Razor »
What else is out there for brickwall-limiting besides the Behringer DCX2496 and DBX Driverack 260? Just curious. Anything under $300?
Re: Brickwall limiter options?
#2 Post by Bruce Weldy »
Razor wrote:What else is out there for brickwall-limiting besides the Behringer DCX2496 and DBX Driverack 260? Just curious. Anything under $300?
While some say the dbx PA or PA+ doesn't have brickwall limiting - I've never been able to get the voltage to go past my limit even when shoving the master fader all the way to the top of the red.
Razor
#3 Post by Razor »
Does that include maxing out the input sensitivity on your amp?
I don't honestly think I need anything more than the dbx Driverack PA+ or PX. Just feel like I'd sleep better at night with a brickwall limiter.
wallywally
#4 Post by wallywally »
Any compressor that has 20:1 or higher ratio and 0ms attack is considered a brick wall limiter. That covers almost every modern compressor.
I seem to recall the reason the dbx wasn't considered a brick wall was because it didn't have the 0ms attack. Although I read that a long time ago and I'm not getting any younger so YMMV.
Builds:
T-39
DR 280
Wedgehorn 8
Omni 12
SLA
TAT
TLAH experimental
#5 Post by Bruce Weldy »
My amps are ALWAYS wide open. Too much room for error any other way. Last Saturday, I was running a rock band outside and the limiter was kicking in occasionally on the kick drum....
I've played 'em outside several times at full tilt and have never blown anything up. I do give myself some room though. I'm limit the 3012LFs at 56 volts instead of the allowed 60.
I wouldn't spend the extra money unless you really need the additional features of a 260.
#6 Post by Grant Bunter »
The BBE DS24 will be under $300, you may find one used cheaper
The newer model BBE DS26 is under $300 new.
There are other brands as well...
Razor
#7 Post by Razor »
I figured the dbx PA+/PX would be enough, was just being paranoid. Thanks for the reassurance. :)
Ryan A
#8 Post by Ryan A »
I use the BEHRINGER ULTRAMIZER PRO DSP1400P. You can get them for less than $100.
#9 Post by Grant Bunter »
ryan222h wrote:I use the BEHRINGER ULTRAMIZER PRO DSP1400P. You can get them for less than $100.
I see that has brick wall limiting, but it's not also a crossover with HP and LP though is it?
SirNickity
#10 Post by SirNickity »
I think his intention was to use the DriveRack with an additional limiter, to achieve a wall of bricks. :-)
Vert
#11 Post by Vert »
Get a good second unit, AVC2 or Drawmer sp0102
#12 Post by Bruce Weldy »
Vert wrote:Get a good second unit, AVC2 or Drawmer sp0102
He's looking for something cheap.....
A used driverack will do everything you need. Don't fret.
Even though there have been posts about the driverack not being a brickwall limiter - I've yet to see anyone post that they've blown a speaker while using one.
Ryan A
#13 Post by Ryan A »
It's not designed to be a crossover, but it will perform that function as well (either broadband high pass or low pass). There's no info about what the slope is on it, though. I suspect its 12db or less per octave.
djtrumptight
#14 Post by djtrumptight »
so i have a chance to buy a Driverack PA+ FOR $200,brand new still in the box.I briefly looked in the manual online and didn't see anything about high pass and low pass filters.I plan to use this with my T-39's and am wondering if i should buy this or just buy another DCX 2496.What do u guys think ?
2 Autotuba's MCM 55 2421
8 T48's 24"wide 3015 LF
2 SLA HT systems
1 Table Tuba Dayton DCS 255-4
2 T 39's 20" wide 3012 LF
1 T-18 13" wide MCM 55 2421
2 SLA Pro's
SirNickity
#15 Post by SirNickity »
There's a crossover. You can set HP/LP on the L, M, H outputs. So yes -- you can use it with T39s.
