hot melt glue
todddlur
hot melt glue
#1 Post by todddlur »
is that the stuff you use a glue gun for in crafts. you just put the stick in and it melts in the gun? or it it a stronger version of it? won't the PL premiun hold the reflectors in? if not why? i know i'm asking a lot of quesrions but this is the onlt thing i'm not sure of. Thanks, Todd
"a painter paints pictures on canvas. but musicians paint their pictures on silence."
Leopold Stokowski
Harley
Re: hot melt glue
#2 Post by Harley »
todddlur wrote:is that the stuff you use a glue gun for in crafts. you just put the stick in and it melts in the gun?
It is indeed :lol:
todddlur wrote:or it it a stronger version of it?
There is but you don't need it for that job. Trust me, you've never had to pull out a stuffed up reflector job yet - hopefully you won't have to, but if you had have, you would realise just how well that hot melt actually works.
todddlur wrote:won't the PL premiun hold the reflectors in? if not why?
It will but it won't do near as good of a job and won't seal the PVC against the wood anywhere as well as the hot melt. With the hot melt, once it is set, you can clearly see any holes/leaks. You must inspect this thoroughly. The rake of the top/bottom piece will prevent the reflector being forced backwards as you will learn when fitting it.
PL works best between joints that are under compression. The reflectors just sit there so you use the hot melt as a filler/sealer much like you would if you were sealing a piece of guttering, or if you have ever welded, like a fillet weld. That's why you must have a 1/8" gap betwen the edge of the PVC and the outer edge of the horn sheath that fits onto the throat horn supports
Illustrative only - Not to scale
todddlur wrote: i know i'm asking a lot of questions
Better to ask now than after you make a GCU :lol:
WARNING: Hot Melt is exactly what it says - HOT. Get it on your fingers or skin and you will have a severe burn
Harley
Edit - typo fix and hot melt warning added
#3 Post by AntonZ »
Thanks for this post and the sketch Harley, I never quite understood why and how with hot melt on this stage of DR construction. I understand now. I suggest this explanation and sketch be stickyfied (moderators please use your choice of either PL or hot melt) for future reference.
vexorgtr
#4 Post by vexorgtr »
There's different grades of hot glue........ if you have a extra high temp glue gun and the industrial grade Hot glue, it works like a champ. The hobby shop glue doesn't always stick that well.... As long as it's glued tight, we're good to go.
Psychic Hamster Audio Works, Pro-Ject:Radiation, and Premium Computer Systems
http://www.premiumcomputer.cc
#5 Post by Bill Fitzmaurice »
AntonZ wrote: I suggest this explanation and sketch be stickyfied (moderators please use your choice of either PL or hot melt) for future reference.
All worthwhile tips like this one are left in place permanently.
Lawrence Langford
#6 Post by Lawrence Langford »
I personally make the reflectors a tight fit, so the wood is what is really holding it in place. And basically the hot glue is just to keep everthing airtight. Just my .02 cents :wink:
Harley
#7 Post by Harley »
Lawrence Langford wrote:I personally make the reflectors a tight fit, so the wood is what is really holding it in place. And basically the hot glue is just to keep everthing airtight. Just my .02 cents :wink:
You and I are both on the same wavelength - that's what I meant by The rake of the top/bottom piece will prevent the reflector being forced backwards as you will learn when fitting it. :lol:
Harley
