2 T60s vs 6 tops
pond
2 T60s vs 6 tops
#1 Post by pond »
Hardly a fair fight, the T60s easily kept up with 3 sets of PAs. Eventually we had the tops placed so they were pointing in all directions.
Initially, we had everything going, 2 JBL 15" Eon powered PAs, 2 Yamaha S115Vs, and 2 EV ELX112Ps all playing >102Hz, with the T60s handling <102Hz. I thought it sounded like shit, the JBLs and the Yamahas were just so 'blaring' and shrill.. I kept walking around and hearing how bad things sounded and turning the volume down, but the other stupid Dj kept cranking it back up. The only area that sounded good was in front of the EVs. Then the cops came and said we had to turn it down, so we killed all but the EVs, and I felt it was a huge improvement in the sound.
So yeah, I need some DRs..
SirNickity
Re: 2 T60s vs 6 tops
#2 Post by SirNickity »
Combining three sets of PA tops is a recipe for disaster. Especially when no attempt at all was made to make them couple. When the three sets are different, you have a whole other set of problems to contend with.
I have a pair of Yamahas (SMs, different shape but same cabinet for the most part) and they sound quite good when used properly and EQ'd. I'm sure the DRs are better, but you really can't hold it against the speakers when the setup is positively wrong from the start.
I hope you don't take offense -- I don't mean any. You're absolutely right, though. This wasn't a fair fight.
Gauss
#3 Post by Gauss »
Nice, thanks for sharing. How would you describe the T60s at this event? Was anything shaking, or were they polite and present?
BASS: Combo Amp & Titan39
pond
#4 Post by pond »
SirNickity wrote:Combining three sets of PA tops is a recipe for disaster. Especially when no attempt at all was made to make them couple. When the three sets are different, you have a whole other set of problems to contend with.
What do you mean 'couple'? They were daisy chained so they were playing the same content.
Gauss wrote:Nice, thanks for sharing. How would you describe the T60s at this event? Was anything shaking, or were they polite and present?
I'd say juuuuuust right. You only get the chest-shaking feeling standing right in front of them, being outdoors and all, but they sounded good no matter where you were standing.
#5 Post by Bill Fitzmaurice »
Their acoustic centers less than 1 wavelength apart unless vertically stacked. 1 wavelength @2kHz is 6 inches, so acoustically coupling them was impossible. What you had there was a comb filtering machine.
subharmonic
#6 Post by subharmonic »
Glad the event went well. As for the tops as you learned as you dropped some out, sometimes less is more, especially when mixing and matching.
I need more bass
CW Mcall
guitarkeys.com
#7 Post by guitarkeys.com »
Anyone else find it odd that someone could be a member of this forum for over 2 years and still not bother to read a single thread about....well...anything...
Jamie
Fayetteville, AR
#8 Post by Gregory East »
So he didn't get the comb filtering memo, no loss of life occurred, onward and upward.
pond
#9 Post by pond »
guitarkeys.com wrote:Anyone else find it odd that someone could be a member of this forum for over 2 years and still not bother to read a single thread about....well...anything...
Anyone else find it odd that someone could be a member of this forums for over 2 years and still be a huge prick? Thanks for your insightful contribution, guy!
Anyway. the picture was taken while we were still setting up. The final resting place of the JBLs was on the ground directly in front of and beneath the EVs, which were on the lowest setting my speaker stands would go to, and the Yamahas were on stands behind the EVs, firing 180* away. Is that setup going to subject to bad comb filtering? What would be the optimal setup given a grab-bag of tops?
pond wrote: What would be the optimal setup given a grab-bag of tops?
Vertically stacked, rotated if required to expand the coverage zone, creating a vertical spiral array.
SirNickity
#11 Post by SirNickity »
What problem are you trying to solve? Not enough output? Or 360-degree coverage? Or both?
SeisTres
#12 Post by SeisTres »
Sell two or four to fund four otops, while keeping the minimum tops needed until otops are done. Once otops are done, running two otops per side. :loler:
No, but really, get rid of the crap and build something decent. I built two 212 otops at his stupid request because he though single loaded otops would not be enough. To this day, he has never pushed the dual cabs anywhere near their limit and regrets having request the dual loaded cabs as 80% of the time a pair of single loaded tops is what he would need.
88h88
#13 Post by 88h88 »
pond wrote:Anyone else find it odd that someone could be a member of this forums for over 2 years and still be a huge prick? Thanks for your insightful contribution, guy!
To be fair he does have a point...
Doesn't matter though, you did what you did and have learned from it so it's all good.
DJ Higgumz
#14 Post by DJ Higgumz »
are those the dual or lab 15 loaded?
Building
4 30" T60s
2 19" T60s
1 30" T39
3 Autotubas with GTO804
Bought
2 Dr250s
